The drum rides on glides in the front and a center bearing in the rear. Those glides are probably gone.
Unplug the dryer and remove these screws then raise the top.
Remove these screws and lift off the front to check those glides
If it is scrubbing you probably need to not only replace the glides
but the glides mount also (called a bearing oddly enough).
Remove the drum and inspect the rear bearinHi i have a GE - themobilian_579.jpgg src="/uploads/images/themobilian_579.jpg" alt="themobilian_579.jpg" class="h_mi" />
I have More repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
