Question about Roper RS22AQXKQ Side by Side Refrigerator
Roper side by side
DIVIDER BETWEEN COMPARTMENTS GETS HOT
  • hermy20 Aug 27, 2008
    our side by side refrigerator between the doors is very hot, cleaned the coils and everything, still hot
  • 481 Answers
Clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way. refrigerators release some of their heat between the doors to prevent condensation, but if it very hot then the machine is not releasing enough heat from its coils under the machine.
Posted on Jul 06, 2008
Middle section divider gets real hot
Any heat inside a refrigerator is a not so good thing, firstly you have to assertain if the thing is in defrost or not, they do this regularly to defrost the ice, if it's hot all the time then you have a problem.
Nov 25, 2013 | Admiral 26 cu. ft. Side-By-Side...
Divider between two compartments is hot model 106.59599990 side by side refrigerator
It is supposed to be hot. Approximately 110 degrees.
It prevents condensation between the doors.
The hot gas refrigerant line is routed through the conduit in between the doors.
It is OK.
Sep 06, 2010 | Refrigerators
The divider between the two compartments of our model106.51564103 is very hot.
This is caused by the condenser running hot due to being dirty or a fan failure, see the link below for instructions and details I put together for this issue. Let me know if it was helpful.
Hot Divider
Jun 02, 2010 | Kenmore Refrigerators
Divider between side by side compartments hot
The area arond where the seals is heated to stop the seal getting damp and mouldy.
Apr 17, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Roper side by side refrigerator gettig very hot to
Most side by side units have a hot return gas line that is attached to the "mullion strip" to prevent sweating or moisture build up which could cause mold to build up on the door seal. The heat you feel is normal, however excessive or continuous heat is a symptom of the unit running too long.
Below is a link provided by www.repairclinic.com, which will help you understand how a refrigerator works.
Tip: Make sure door seals are sealing adequately and keep entry time to a minimum during high heat periods. Use the rule "Get in, get what you want and get out"
http://www.repairclinic.com/0088_4_3.asp
Aug 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Roper center divider hot
Either a bad condensor fan motor ( fan which cools the compressor ) OR dirty coils . Remove the kickplate and vacuum .
Aug 02, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Divider between freezer and fridge is HOT to the touch
That is a heat strip to prevent condensate near the door seals and yours is possibly shorting out because the control fo it is defective. Send me the model number for your Roper and I will look at the diaqrams to confirm my theroy. Thanks, Sea BreezeEnter your model number at the link below and it will take you to the parts and photos.http://servicepartstec.blogspot.com
Jun 05, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
150 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
