Question about Navman PiN 570 GPS Receiver
P570 help to hard wire my navmanp570
    Problem Solver:
  • 12 Answers
Can you explain what you are hard-wiring?
Posted on Oct 26, 2008
Having to replace factory fitted radio/cd auto electrician found wiring behind radio hard and easily broken so unusable. Is wing hard to replace
Its not to hard if u are capable of running wire. First off most aftermarket radios have generally the same wireing red is power to key yellow is power strait to the battery and black is ground now depending on the radio you buy there will be one or two blue wies one with a white line the one blue wire with white line is your power antenna wire if you have a power antenna the other blue wire is for added components like an amp for your subs if you have one. Now there 8 wires that will be green, green/white, purple purple/white, white, white/black, grey, grey/white and those are all your speaker wires front and rear channels. There might be more wires like auto dim and mute and so on but most of the time nobody hooks them up because thay are not needed. Hope this helps good luck.
Sep 01, 2015 | 2005 Toyota LandCruiser Prado
2000 pontiac grand am gt radio wiring harness cut need to know how to hard wire in
most of these car the plug is simply a plug for convieince you dont need it to hard wire it you simply match up the colors most of them will be the same and then if there are any left over you should be able to do process of elimination hope this helps
Feb 22, 2014 | 2000 Pontiac Grand Am GT
Steering column repair
Hi Mralaniz, I'm glad to help!
If the dealer doesn't carry the wiring anymore then you'll need to call the "Junkyards' to see if they have one. If they don't you'll need to rewire it one wire at a time. Hope this helps and have an awesome day.
Apr 23, 2013 | Buick Skylark Cars & Trucks
Replace hdd
turn off the computer and unplug from wall
open the case/tower
remove wires from hard drive
remove screws from hard drive
remove hard drive and replace with new hard drive
replace screws
replace wires
close up the case
turn on the computer
Does that help?
Dec 27, 2012 | Computers & Internet
What does "hard start" mean
The compressor is having trouble starting. You can wire in a hard start kit to help the compressor start. Its easy the hard start has two wires one goes to Common on the capcitor and the othe goes to the HERM terminal on the capacitor.
Jul 19, 2011 | Heating & Cooling
Hi i'm from greece and i bought a hitachi simple drive external hard drive 1 tb about 4 months ago it worked fine but now suddently it stopped . i tried to take it of the power and i also removed the cable...
you must have short in the wire hooked up to external try jiggling the base of wire pluged up to port on the external see if you see the light on hard flicker on off if thats the case its your wire for right intell you get a new wire prop something underneath wire intell you see the light stay on.
Feb 24, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My hard wired light timer pulsates when on
I have the same problm. 2 in wall, 4 on timer. And it clicks on and off when set to "on".
Please help.
Paul
relaxrn@hotmail.com
Apr 11, 2010 | Directed Electronics Pulse Timer with Spdt...
Navman PiN 570 GPS Receiver Logo
54 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
