Question about Kitchen Ranges
Ignition spark on Neff hob is continuously firing - ie after the gas is lit it keeps on going. How can I stop it? Very annoying.
  • 14quills Jul 07, 2008
    Cheers. Am guessing I need to get this replaced then?
Neff problem where igniters dont stop...the hob top is held by the 4 knobs which pull off, then 8 small phillips screws, 2 by each burner...underneath the knobs you will find a plastic slider which has a spring...is the spring OK? does the slider slide! a little WD40 might make things go a little better, maybe stretch the spring a little and make sure that the 4 rubber seals where the knobs go thru the top are fitted correctly and don't foul the slider.
That fixed it for me. We had been putting up with that problem for years and stopping the igniter by flicking another knob. In fact it only worked properly for a few months after new.
I used some 3 in 1 oil on the plastic slider and it slid much easier allowing the spring to bring the slider back and the switch off. It is not a good design because the reactive force of the switch tends to make the slider bend up at the switch end and causes the track to bind. My guess is that is will need re-lubricating again in a while. A stronger spring might be another solution.
Posted on Aug 07, 2010
    Champion:
  • 254 Answers
This is caused by a failing flame switch. It will have a copper line coming from the pilot igniton block back to a switch that will have two wires on it. usually these are blue and white in color.
Hope this helps Ya
Posted on Jul 06, 2008
  • burzerko
    burzerko Jul 09, 2008
    Yes you will need to get this replaced.
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
Sparking ignition
switch Is stuck in on position
Apr 15, 2008 | Tecnik 27 in. TKH3515SS Gas Cooktop
Kitchen Ranges Logo
2,121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
