Question about Kitchen Ranges
Light on my gas Bosch convection range is not working from the push pad. It goes on when the door is opened. Could be Sabbath feature somehow. I do not use it but could it have become activated??? The timer was not working either lately until I reset the factory options using Select Funciton Menu. Then the light came on and now I cannot turn it off...
  • juliejensen4 Jul 06, 2008
    It is a Bosch HGS7022UC/01 gas Range it was installed in 2007.
  • 4,889 Answers
Are you talking about the ignitor or the the automatic oven lights?
Posted on Jul 06, 2008
    Master:
  • 497 Answers
May i have the make and the model number please..
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
I have a sab error message
Hello, welcome to FixYa.
The message you are receiving is not actually an error, but rather your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the band, lol ) If you have the owners manual refer to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently. This example is generic, hopefully it works. If you are unsuccessful let me know and I'll see if I can locate it.
Hold Clock pad for 5 seconds to activate Sabbath mode. Hold Clock pad for 5 seconds to disable Sabbath mode.
Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
This mode disables the normal 12 hour shutoff to allow operation of the bake mode for a maximum of 72 hours.
Good luck. Thank you for choosing FixYa. If this does resolve the issue, please take a moment to rate the assitance I provided as well as your experience here at FixYa.
Regards,
Macmarkus :)
Sep 19, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
The electronic panel related to oven and clock does not work. code 5ab appears on the display
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the metal band, lol ) If you have the owners manual turn to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know the exact model number and I'll see if I can locate it.
Regards,
Macmarkus :)
Jul 18, 2011 | Maytag Gemini 30" Self-Cleaning...
I get the error code 5A6 on the digital display What do I do? Is there way to reset the display? Need I replace the display, the circuit board? If so, where is the the best place to purchase needed parts?...
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the band, lol ) If you have the owners manual refer to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know and I'll see if I can locate it.
Good luck.
Regards,
Macmarkus :)
Jul 11, 2011 | Amana AGR5735QDS Gas Kitchen Range
My stove and oven froze with an error of 5ab6 bath or 6ath wont do anything
Sabbath feature.
These stoves are programmed for the sabbath.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Jan 22, 2011 | Maytag MGR6775 Stainless Steel Kitchen...
How do I activate the Shabbos (Sabbath) Mode.
To
ARROW pad.
"3".
shut-off.
Oct 22, 2010 | Maytag MER6772 Gemini Electric Kitchen...
My maytag gas range have a error message 5a6. I
The error your range is displaying is actually "SABBATH", which is Sabbath Mode. This enables the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, this range is equipped with a Control Lock-Out feature, rather than a Sabbath Mode. To cancel the Control Lock, you need to press and hold the STOP/TIME and CANCEL pads down at the same time for 3 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format.
If you have questions, please post back with your correct MODEL NUMBER (if different from the one I provided) and let me know. I hope this helps you.
Jun 30, 2010 | Maytag MGR5750 Gas Kitchen Range
I need instructions on how to use the sabbath mode . the instruction manual is misplaced.
I found this for electrolux models on my pc , maybe you can try it on yours or get an idea how it works. All features are about the same.
To
ARROW pad.
"3".
shut-off.
Other Displays:
or
should
stay on USE.
Sep 13, 2009 | Kitchen Ranges
Range shows 'SA 66" in display
After calling customer service with no satisfaction, I did a Google search for SA66 which turned out to be really SAbb code. I found out that this is a special "Jewish Mode" that I somehow turned on while pushing the touch pad disabling it. To end the "Sabbath Mode", Press CANCEL/OFF FOR ONE SECOND, then press and hold Number Pad 6 for five seconds. It worked!
(You can also press and hold the Number Pad 6 for five seconds first, followed by CANCEL/OFF.)
Mar 07, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
