Question about Whirlpool Kitchen Ranges
How to remove the oven sensor whirlpool model rf374pxgq1
  • unkel Jul 06, 2008
    That is the model number RF374PXGQ. The sensor probe is in the upper right and does not have any screws from inside the oven.
    thanks for your help.
    Thanks, Unkel
  • burzerko
    burzerko May 11, 2010
    please check that model number whirlpool tells me its invalid
    Champion:
  • 254 Answers
Ya follow regs advice he posted a great solution there.
Posted on Jul 20, 2008
  • 413 Answers
In most cases, the oven sensor can be removed from inside the oven cavity. Two screws secure it to the back wall of the cavity. The probe will have a connector on one end which can make it troublesome to remove and/or reinstall. If necessary, remove the back panel.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 06, 2008
On a whirlpool double oven what does F2 error mean and canit be fixed
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. If present, replace control board (clock). For SELF CLEAN models, check door lock operation. Check sensor, sensor harness, and the sensor harness connection at sensor and oven control. Also check for any causes of high resistance in the oven temperature sensor circuit. Remember: The oven control board (clock) measures resistance of sensor circuit, not actual oven temperature.
Nov 23, 2016 | Whirlpool Ovens
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Troubleshoot oven temp model#RF388LXKT0
The oven tempature is controlled by the oven sensor and if the temp. is off the sensor is very likely the problem. To test the sensor it should be unplugged from the wire it plugs into and use a multimeter set to measure ohms of resistiance and check the sensor at ROOM TEMPATURE to be between 1060-1100 ohms if its substantially higher or lower that 1060-1100 when checked at room temp. the sensor is bad.
The sensor is located in the oven chamber and it can be removed to test it by unscrewing it from the back wall of the oven cooking chamber,here is what it looks like oldtech2332_140.jpg
GENE
Oct 13, 2011 | Whirlpool Kitchen Ranges
I have a Whirlpool Oven model #RBS275PDQ17, Serial #XS2200683 Oven. When I put the temperature on 400 degrees for 1 hour, it started for about 3 minutes then it displayed E2 F-3 and locked. This happened...
Oven over heat Replace Sensor
Before you order any parts remove the oven sensor quick connect and look for corrosion. Test the sensor; should be around 1100 ohms at room temp.
More here
May 16, 2011 | Whirlpool Ovens
Whirlpool gas range error code f2
Hi sauerteig_j,
Whirlpool F2 error code indicates that oven temperature is too high. And to fix this problem:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just have your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Feb 08, 2011 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool SF36 Gas Oven - F3 F2 ERROR above 350 degrees
Unplug the range.
The oven temperature sensor has failed and must be replaced.
Remove the racks. Remove the temperature sensor located up high on the back wall of the oven.
It is a short thin round piece of metal.
Feb 13, 2010 | Whirlpool SF369 Gas Kitchen Range
The clock on my wall whirlpool oven flashes a error code of F2 and beeps on and off?
F2-- Oven temperature is too high
Jul 09, 2009 | Whirlpool GMC275PRS Oven
I have a whirlpool gas oven model # SF395LEEBO
Oven temperature sensor opened Replace oven temperature sensor
Jan 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
Kitchen Ranges Logo
90 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
