Question about Cell Phones
Which button to activate pairing with phone - Cell Phones
  • mukwano Jul 06, 2008
    Thanks for the help - I found that the bluetooth manufacture had a walkthru "fixit' on their website for "setup" I appreciate your response.
  • 51 Answers
Well.. check out the options in settings of ur phone..
Posted on Jul 06, 2008
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How do I answer a call from my headset?
Is the headset paired with the phone you are using? If not, you can pair the headset by pushing and holding for a few seconds a small button on the back of the 5330 phone until it starts flashing. The button should be near the top of the cordless module. When the phone starts flashing, push and hold the answer button on the headset until it starts to flash as well. There should be a prompt on the phone itself to select which device you want to pair. Let me know if this helps :)
Jun 10, 2014 | Mitel 5330 IP Phone
How do i get supertooth to work with my phone NO MANUAL
You basically have to make a connection , to pair them ..and after that they will work together ..To do that look for a button on the device that will activate it ..or if it do not have it means that the power on button will activate it ..and after that start the bluetooth on the phone ..and use the search for device feature to locate the supertooth ..and pair them ..(connect ).
Nov 14, 2011 | Radio Communications
I have an orange amsterdam phone trying to pair with bluetooth and it asks me for an activation code. I have never set one and the book doesn't tell me what the factory setting is
Pairing is a two part activity. On the device you are trying to pair with, you will need to set it to search for a bluetooth device to pair with. On that device, it should give you an activation code.
For example, when pairing with my car, I go into the menu, phone, and "pair". It tells me the activation code is 0000 (pretty common one, so you may want to try it). I put this in, and the phone pairs with the car.
May 26, 2011 | Orange Cell Phones
I purchased a used 2004 BMW 325ci. When I try to pair with the bluetooth it comes over the speaker saying your verizon account is no longer active. This is obviously from the previous owner. How do I...
Do you have the owner's manual for your 325ci? If so, have you checked the phone pairing section? The button on the steering wheel is probably not for pairing but rather for using the phone. Most likely you need to pair through some sequence of buttons/menus from the infotainment system.
Dec 16, 2017 | BMW 325 Cars & Trucks
How do u pair supertooth visor go to phone
Put your bluetooth on your phone..
On the supertooth is a green button..press and hold to turn on for around 5 secs and watch for red and blue lights to flash..its pairing mode..now activate phone discoverable. .and pair..enjoy
Aug 05, 2010 | Handspring Visor Prism Handheld
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
Apr 03, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Seal handsfree not pairing
with the phone's bluetooth active
press button to turn the seal device
press blue button on seal device
on phone, select pair new device
when the seal device is found, use code 0000 to pair the phone to the device..
next time you connect, turn on the phones bluetooth and the seal device. press blue button on seal device. it should automatically pair.
Sep 15, 2009 | Handspring Visor Prism Handheld
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Open Questions:
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
