Question about Intel D845GVSR Motherboard
Problem of Modem and RAM
I want to update BIOS how can i do it. which ram of 1GB capacity is compatile,pc cannot detect port for nokia mobile modem
  • 1,031 Answers
Go to the bios manufactures web site check for the latest bios update and download on your systems then use it to upgrade you bios
Posted on Jul 06, 2008
I WANT UPDATE MY BIOS. BIOS : AWARD MODULAR BIOS V 6.00PG BIOS ID : 09/25/2001-i810e-W8362-6A69MTRAC-00 DATE: 9/25/01 RAM SIZE:256K BIOS OEM :SE-810ET/MT/MF VER. 3.2(2003.10.18-2MM CHIPSET : INTEL WHITNEY...
Bios updates should only be done when absolutely necessary because, often, they run in problems and you then have no computer since your bios is now messed up. If you still want to do it get the upgrade bios from the mo bo manufacturer and use software that will also backup what you have in case of disaster. A word to the wise.
Aug 05, 2017 | Intel Computers & Internet
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Can Windows 7 be installed on X05? I get ACPI incompatible BIOS and have updated to last known one. Please help!
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram. I run windows 7 on 2GB and its great, your machine will take 2GB. The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine. i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
  • 1GHz CPU
  • 1GB of RAM
  • 16GB of drive space
  • DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
  • BELOW YOUR MACHINE SPEC
  • MPN nx05tp8e0a/suk
    Key Features
    Laptop Type Thin and Light Laptop
    Use Corporate Business • Small Business • Business
    Processor Pentium M 1.5 GHz
    Installed Memory 256 MB (DDR SDRAM)
    Display 14.1 in. XGA TFT LCD
    Operating System Microsoft Windows XP Professional
    Mobile Technology Intel Centrino Mobile Technology
    Processor
    Processor Manufacturer Intel
    Processor Type Pentium M
    Processor Speed 1.5 GHz
    Motherboard
    Chipset Intel 855GM
    Bus Speed 400 MHz
    Memory
    Installed RAM 256 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 2048 KB
    Hard Drive
    Hard Drive Capacity 30 GB
    Storage Controller Type Ultra ATA 100
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 8x (CD)
    Optical Drive ReWrite Speed 8x (CD-RW)
    Display
    Display Tech XGA TFT LCD
    Screen Size 14.1 in.
    Display Max. Resolution 1024 x 768
    Video
    Graphic Processor NVIDIA GeForce4 440 Go
    Graphic Bus Interface AGP x4
    External Video Resolution 1920 x 1200
    Audio
    Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
    Audio Input Type Microphone
    Operating System
    Platform PC
    Technical Features
    Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
    Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
    Input Method Keyboard • Scroll Button • Touchpad
    Networking
    Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
    Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.90
    Battery
    Battery Run Time 2.2 Hours
    Battery Technology Lithium ion
    Dimensions
    Width 31.5 cm
    Depth 25.9 cm
    Height 2.4 cm
    Weight 2 kg
Nov 05, 2009 | Samsung X05 Notebook
I have recently upgraded my ram from 516 to 2 x
Try installing one module only. (You may have to try in first slot, and then if it does not work, in the second slot.) If the 1gb module is recognized install the second one.
If all else fails, the modules may be incompatible with your motherboard, or 1gb exceeds the capacity of the slot.
Hope it helps
Aug 29, 2009 | Computers & Internet
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
BIOS UPDATE FOR 810et MOTHERBOARD
goto their website and download the latest bios for your system.
May 02, 2009 | Computers & Internet
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
Unable to detect modem for nokia 6070
download 6020 cable modem drivers from http://europe.nokia.com/A4144316 (yeah, no modem drivers for 6070). then go to device manager and update modem drivers to downloaded one.. that only will do.
Jan 25, 2008 | Nokia 6070 Cellular Phone
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
