Zebra TLP 2844-Z Thermal Label Printer
Problem for Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844
By Jimmy NY - usenet poster
For barcode printer : Zebra TLP 2844.
Is there anyway to find a way to print via drivers in word (By using
fonts) - I don't see a way to declare the size of the label, with not
directly printing. Also, fonts for barcode etc...
Nevertheless, I would like to know the codes for direct printing to barcode
Help, please.
Same Problem
Feb 20, 2008
-   Hi, I have a problem with the Zebra TLP 2844-Z. After the driver installation the printer won't print with any Windows applications such as Word except the software offered by Zebra. But I need to be able to print with all Windows applications.-   Guest
Solution #1
posted on Sep 05, 2009
Not Rated)
abu_habeeb
Rank: Apprentice
Rating: 0%, 0 votes
Hi
How to Print bachprint
Was this helpful?
Yes
No
Solution #2
posted on Jun 08, 2009
Not Rated)
r_imran
Rank: Apprentice
Rating: 0%, 0 votes
I've Zebra TLP2844, it is on USB interface. how i can add that printer to ZDesigner on a network machine. can i use it as a shared printer on other machine and how...?
Was this helpful?
Yes
No
Solution #3
posted on Apr 18, 2009
Not Rated)
jiminyfixya
Rank: Wiz
Rating: 90%, 7 votes
The Zebra 2844 uses EPL Eltron Programming Language
The 2844-Z uses ZPL (Zebra Programming Language)
The Zebra software supplied with these printers is called "Zebra Designer" and it uses an internal printer driver. "ZDESIGNER LP2844" or "ZDESIGNER LP2844Z". These drivers only work with "Zebra Designer"
Zebra printers use a windows driver. it can be downloaded directly from the Zebra website. This driver or "ZUD driver" installa itself as "Zebra LP2844" or "Zebra LP2844Z". With the zud driver installed you can use any windows application to print to a zebra printer E.g Word, Excel....etc.
To print directly to your 2844 you must write your code in EPL.
The EPL programming manual can be downloaded from Zebra website.
I hope this helps.
Was this helpful?
Yes
No
Solution #4
posted on Aug 11, 2005
Not Rated)
Bouncy
Rank: Apprentice
Rating: 0%, 0 votes
If you are using one of the drivers from Seagull Scientific, you can
add a specific page/label size into the driver for the settings you
want. When you have selected the Zebra as the printer, this page
format will then appear as one of the selectable paper sizes on the
page setup screen (or I guess you could save it as a document
template).
With the Zebra driver selected the Zebra text fonts should now also
appear in the font selection window. Bar codes however will be a
problem as I don't think you can directly address the printers
in-built bar code fonts from there. You could use a bar code ttf file,
but the drawback to this is that the file will be sent to the printer
as a graphic file rather than a label format.
You can download the programming manuals for the TLP 2844 from Zebras
website (www.zebra.com), but you need to know whether you have the
standard 2844 or the 2844-Z model as they use a different programming
language EPL2 or ZPL respectively.
Pete
Was this helpful?
Yes
No
Solution #5
Not Rated)
Powe33
Rank: Apprentice
Rating: 0%, 0 votes
"Pete Thane" wrote :
Thanks, I have TLP-2844 (without the "Z" - it's not on the label that is on
the printer, or on papers I've got with the printer).
I didn't find any manual or tech-reference about codes for direct printing,
either on the site www.zebra.com  nor on the papers I got when I had the
printer.
I didn't find other simple way to print.
Right now, I should prefer to print directly to the printer (without any
driver), because something I've got.
Help, please.
Was this helpful?
Yes
No
Popular Solutions for Zebra TLP 2844-Z Thermal Label
Questions and Unsolved Problems for Zebra TLP 2844-Z Thermal Label
Do you recommend Zebra TLP 2844-Z Thermal Label Printer?
Answer
Answer
TLP 2844-Z doesn't print label barcode in 30 x 1,5 mm I have installed Zebra Designer to make a... (More)
Answer
i have a probleme with tlp2844,led error is in red position it can't boot firmware
Answer
trying to print label on Herma template but does not align well? pls help. thx
Answer
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zebra TLP 2844-Z Thermal Label...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
