Question about Frigidaire FEF365AS Electric Kitchen Range
Locking Issue Hi. I am having a problem with my range. I was in the middle of cooking and the locking mechanism came on. I opened the door while this was happening so now the door will not shut and the lock will not go back in.
  • 254 Answers
Let me see if I can help you. I see three components that make up the locking mechanism. The 1st is the door latch itself, the 2nd is the linkage that runs from the door latch to the lock motor. The 3rd being the lock motor. When you try to lock it can you hear any clicks or a motor hum? Also have you checked to make sure the reciever is in the open position on the latch to ensure that the latch will function in the correct position? There should also be a spacer just to the right of the latch reciever make sure that it is in place as well. If you have any other questions please feel free to comment me.
Posted on Jul 06, 2008
  • 497 Answers
You might have a fried ERC. This would mainly affect ovens that have automatic door latching in self clean Check for error code in display. If an error code is given, check against manufacturer’s code explanations in owner’s manual or tech data sheet inside oven control panel. You’ll need to disassemble the oven to get at it.
All the best
  • 4,889 Answers
There are 3 things you can try and atleast one of them will work.
1)hold in the door button and push broil until the latch makes a 360 degree then the door lock should stop flashing and the oven will work again
2)press and hold the lock button for about 3 seconds.
3)push and hold in on the door switch with the door open and push cancel will reset
Let me know if it worked.
  • eagle338
    eagle338 Jul 09, 2008
    Hi you contacted me on my profile and haven't heard of you since then?
Magic Chef Range - oven door won't open Gas Oven with stove top 1980's Model 64DY-3CKXW all dials/no electronic displays There are two dials for the oven One that controls the temperature and another that...
If a selfclean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Most self cleaning ranges today use one of 3 different types of door locking systems. One design is solenoid driven, another is heat activated and the last, motorized.
  • A solenoid controlled system can be identified by the lever that must be set to lock the door, plus a loud buzzing or clunking noise heard when locking or unlocking the door.
  • The heat sensitive lock mechanism also has a locking lever but makes no noises. It instead utilizes a coiled spring to slowly lock the door as the oven heats.
  • The motorized design has no lever to move, the motor locks the door by itself when the range is set for self clean. The motor may have made an audible whining or ratcheting sound when in use.
A motorized or heat sensitive style lock will usually be located beneath the cook top on free standing ranges. The cook top would usually need to be lifted to access the locking mechanism. On built in ovens, the oven must usually be removed from its enclosure (or at least partially) in order to remove the top panel to gain access to the locking mechanism. On some built in oven models, the lock assembly may be able to be accessed by removing the control console.
sc-lock-geheatsensitive.gifOn the heat sensitive style (illustrated), there are no electrical parts used to operate the lock which could fail, so the whole mechanism will usually need to be replaced if not operational.
With the motorized lock mechanism, a volt/ohm meter is required to try to determine why the locking motor will not operate. The failure could be in the motor itself or the power supply leading to it, including a door activated and/or console mounted switch and switches on the latch mechanism itself.
On solenoid activated designs, the solenoid coil is a common failure point which is often mounted on the back of the range. On many of these models, the lock mechanism can be accessed by removing the rear panel of the appliance. Some models such as built-in ovens or drop-in/slide-in ranges, may have the mechanism mounted towards the front, under the top.
sc-lock-gelocksolenoid.anim.gifFailure of a solenoid style lock is most often caused by a bad solenoid. Once the lock is located, the solenoid coil can be checked for continuity. Some latch assemblies also have micro switches in the power supply that will need to be checked for faults too.
Be certain to unplug or remove power from the range before undertaking any repairs yourself and follow all standard safety precautions.
usually if you are unable to open it after all these tests then you would resort to manually opening the door by getting a piece of wire and slip it where the latch mechanism is and prying to the left this is a last means resort so try these other ways and get back to me with any further questions that you may have and please remember to rank how this opinion has helped in your appliance situation Thanks again
Dec 18, 2010 | Magic Chef Ovens
Cleaned oven door lock wont release, cant cook
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Nov 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Honda Civic: a locking/unlocking issue
if it is a central lock mechanism then it should lock all doors. check the motor/solenoid of each door. also the electrical connections.
Oct 03, 2009 | 1996 Honda Civic
Oven will not come on to cook, it will come on in cleaning mode
I've seen this problem on my own oven. If yours, like mine, has a door that has a locking mechanism, the catch is most likely stuck in the locked position. The door still closes and the lever still moves (though it may be very stiff).
Take off the screws around the locking plate, manually push the catch to the open position, spray the catch VERY, VERY lightly with WD-40 and dry it thoroughly. Close the oven door and try the lever again.
At this point, it should move freely and your oven should be able to switch between LOCKED/Self-Clean Mode and UNLOCKED/Cook Mode. If it does still get stuck, you'll just has to a) try lubricating the catch a bit more or b) keep a screwdriver handy! ;)
Aug 05, 2009 | Hotpoint RB757 Electric Kitchen Range
Locking door wont open
the self cleaning lock is stuck and I can't open the oven, how do I fix this
Jan 19, 2009 | Hotpoint RB757 Electric Kitchen Range
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
I used my speed clean fixture for the first time today. It ran for 2 hours this morning (9am), but I cannot open the oven door now. The door lock light is off and it should be cool by now. Error code...
I had the same issue when I used the clean feature for the first time. I opened up the back and found the door locking motor in the middle of the range. I ended up taking off the power wires to the door lock switch and motor and tapping the motor a few times. I reconnected the power and the door lock opened. No problems since, but I don't think I will try to automatically clean the oven again!
Nov 09, 2008 | Frigidaire Kitchen Ranges
Oven door locked
unplug unit and plug it back in if that does not reset the locking assembly.Unplug unit remove back panel and look for the locking assembly.It will have a rod that goes to front where door is.Remove locking assembly to release rod and replace locking assembly.
Nov 24, 2007 | Frigidaire FEF336BC Electric Kitchen Range
"Locked Door" flashes after interrupting self clean
Robert, see if you can get it back home by using the test funtion. Kill the power to the oven. Turn it back on and on the control press and hold the cooking time and delay start pads together. While hold these keys, press the number 8 pad. The words test should appear in the display. Now press and hold the self clean pad and it should cycle the cam through the whole process. Here is what you should see. 1 test (unit is in unlocked position 0 test (moving toward latched pos. 2 test (latched position 0 test (moving toward unlocked pos. 1 test (unit is in unlocked pos. Press cancel to exit the test. See if this gets you going again, let me know, Catriver
Aug 24, 2007 | GE JBP60 Electric Kitchen Range
Frigidaire FEF365AS Electric Kitchen Range Logo
143 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
