Question about Microwave Ovens
I have a recently purchased microwave since CHristmas. It was working wonderfully. Recently, I moved and plugged the microwave back in. THe light is on but will not program anything. I tried to plug into another socket. Still the light goes on, but will not let me plug in anything. The motor sounds like it is running, but nothing is happening. The turn table does not even move. Style JES1136WL01 Serial Number LM904360B Rodney Peterson bc2of135@kmtel.com 507-634-4411
  • drews4 Mar 03, 2009
    Mine is less than a year old. One day it started just shutting off part way through or it sounds like its running but its not.
We have the same model. It's a piece of garbage. I loved the retro oval window and all and the size was perfect for our space. Then, the paint started chipping off the inside front, the timer started working intermittently, and the oven would just quit in the middle of the cooking cycle! Today, it finally just up and died. I unplugged and replugged it. No go. Finished cooking on stove top. My suggestion? Do like we're going to do and go buy another microwave...not another GE!
Good luck! Peacenikkie@charter.net
Posted on Aug 01, 2008
Recently purchased this microwave (4-5 months ago) 5E error light comes on. Unplugged worked for short period - lights came on and off, things started beeping and the 5E came back on. Have repeated this...
"SE" means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable.
Since it's under warranty, I would contact Samsung for a free fix. See your owner's manual.
Jul 06, 2011 | Samsung SMH9151ST Stainless Steel 1000...
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
I recently bought a breville deep fryer model DFY80 and it doesnt seem to work, but it doesnt have any oil in it yet. So i was wondering if i need to put oil in it before the lights and thermostate work??...
there is a reset button on the back of the element box try that and there is a switch when you slide the element into the frame make sure that it is making contact .hope this fixes your problem. dave.
Oct 26, 2010 | Microwave Ovens
Recently the light flickers and gets dimmer, then back to normal, several times while heating something in the oven Just wondered if this is some simple thing to take care of, or should we consider...
Sounds like an arcing switch or connection, or maybe the light itself is not making a good connection. Check the plug in the outlet socket to see if it gets hot after heating something. Wiggle the cord to see if the light flickers. The door switch is a microswitch type and should make a positive 'click' when operated.
Feb 05, 2010 | Microwave Ovens
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
The fuse blows when i plug the microwave in with the door closed
first you gotta detach the button plate ( the thing with all the buttons) using a flathead screwdriver .Keep pushing it is stuburn. It will pop back in when you are done. the fuse is behind that. just take it out and put the new one in.
Nov 16, 2008 | Microwave Ovens
Microwave causes all appliances to shut off
A surge protector will not help. The circuit that you have the microwave plugged too is overloaded or the breaker is weak.
You need to find out which breakers in your switch box operate which outlets. Then you may be able to move some of the appliances to different recepticles that are on different circuits.
Turn the lights on in all the rooms.
Got to your switch box and turn off one of the single switches(not the ones that are two switches hooked together).
Then go to each room and check to see which lights have went out. Take a lamp or small appliance to each wall plug-in and see if it has power.
When you find out everything that switch controls, write it on a piece of paper so you will know in the future what that circuit has on it.
Turn that switch back on and repeat the process with the next switch and so on and so forth until you have written down what each breaker controls.
Now you will have some idea which circuits have the most load and which ones you can move something to.
You also need to call your landlord or building super to check to make sure the breakers in the switch box are in good condition.
Hope this helps.
Nov 11, 2007 | GE JES738 Microwave Oven
Microwave Ovens Logo
108 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
