Question about NetGear WGR614 Wireless Router
My netgear wgr614 wireless router v3
I cannot using 192.168.0.1 or 1.1 access to login why?what is a workaround if available
  • 9 more comments
  • LDBLDB Jul 06, 2008
    my os is vista ultimate 64bit;
    no gateway is listed ;
    there is no support tab under local area connection status
    packets: sent=427 received=0
    ipv4/v6 connectivity is limited
    media state is enabled
    speed 1gbps
    the default gateway address.for ipv4/v6 is not listed therefore i could not yet:
    Type that address in using internet explorer. Type in the user Id and password to the router
    no icon at bottom of screen that says gateway. what's next
    thanks for your help--i'm patient.
    thanks for your referral this may take some time to read thru. there is a detail that may be helpful to solve this:
    my internet isp connection is wireless via an usb2.0 port on my 64bit vista ultimate 64bit os computer; the netgear wireless router wan port is connected via the computer's 1gbps lan port; yet there is yet no way to login to nor find yet the gateway address. if the work around is simpler because of this detail let me know otherwise i'll continue with this monday night. thanks
    sierra wireless aircard 595u firmware version p2010002
    does the wireless adaptor in my computer need some setting?
    the lan port has 0.0.0.0 as the default gateway;the aircard wireless gateway is 68.28.58.92 is this helpful to solve the problem?
    i was unable to login using the aircard's gateway
  • LDBLDB Jul 07, 2008
    the aircard plugs into a usb2.0 port on my non-laptop computer
    listen.do.biz@gmail.com
  • mensah_gh200 Jan 04, 2009
    i can not get network when am use the wireless i can see that is connection but is not opned
  • 2,794 Answers
Go into the control to see your network connections.
find you network connection. Press the right mouse button and select status. Press the support tab and look at the default gateway address.
Type that address in using internet explorer. Type in the user Id and password to the router and you should be in
Posted on Jul 06, 2008
  • 5 more comments
  • Tim Babcock
    Tim Babcock Jul 06, 2008
    That setup is different. Press the windows button on the lower left of the screen and look for your network. On top of the screen are three icons. Press the center one and see if that will get you in.
  • Tim Babcock
    usually the gateway is created in the network section. You might want to look at the botom of the network screen for an icon that says gateway on it. Click on it and that should get you in.
  • Tim Babcock
    I got Vista at work but not at home. If you don't get an answer today, I can find out tomorrow.
  • Tim Babcock
  • Tim Babcock
    Whats the make and model of the wireless adaptor in your computer?
  • Tim Babcock
    Tim Babcock Jul 07, 2008
    Is the computer wired in or running wireless?
  • Tim Babcock
    Do you have an email address I can send you some information?
Download smart wizard instalation assistany wgt 624
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 25, 2013 | NetGear WGR614 Router
Need password for wireless router netgear wgr614 need password to set up wireless i pod
The default login is user = 'admin' and password = 'password' for the router. Only type what is between the quotes. If you changed and forgot your password, there is a reset button on the unit. Press the button until the power light flickers (about 10 seconds). You should now be able to get in using the default login.
Jun 16, 2011 | NetGear WGR614 Wireless Router
How do i add aditional routers to gain access to the network from a detached shop using wireless
Connect your addition routers to NetGear WGR614 Wireless Router port ,Use NetGear WGR614 Wireless Router as a switch ....
Check if it works
Thanks
Snadeep
Mar 08, 2011 | NetGear WGR614 Wireless Router
Netgear wireless router wgr614?
If you cannot login to the router's configuration URL, then you can reset the Netgear back to the factory defaults by powering up the router and press the pinhole RESET button at the back of the router until the LEDs turn on, then release the RESET button and wait for the router to reboot.
Then connect a LAN cable from the computer to the router open an Internet Browser and enter the router's configuration URL
http://192.168.0.1
The default password = password.
You can now configure the wireless settings, Eg. SSID, encryption etc.
To secure your wireless from unauthorized access, please click on this link and follow my instructions :-
Jul 11, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Laptop shows connected to network via netgear router wirelessly but wont connect to internet
I would recommend checking that your laptop is set up on the access list in the router. Login to the router and check the settings.
May 26, 2010 | NetGear WGR614 54Mbps Wireless Router...
Forgot my wireless internet password
You have to login to router ,for wireless password
following is the way to login to router
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
Hope it can resolved your issue
please rate the service if issue resolved
Thanks for using Fixya
Apr 04, 2010 | NetGear WGR614 Wireless Router
Lost instruction
Lost instruction - NetGear
Nov 05, 2009 | NetGear WGR614 Wireless Router
Having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the router...press and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : admin....it should work
Netgear address : 192.168.0.1 ( Type in IE address bar to access it )
Regards,
Anup
Apr 06, 2009 | NetGear WGR614 Wireless Router
I have this unit Netgear 54 Mbps wireless router WGR614 v6
Sorry but to give you complete details is not something that I or anyone can take the time. Go to netgear.com and look in their support section, lookup your router and download the manual. latest firmware is available there as well, there is no drivers for a router.
Apr 03, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Wireless router PPPoE login info
PPPoE login n password is from your Internet Service Provider that you sign up with.
Jul 15, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
110 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
