Question about Maytag Refrigerators
My maytag fridge frosted up and got warm. I let it sit turned off for about 4 hours and it sems to be working fine now. will this reoccur?
  • 481 Answers
Yes it will frost up again, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
The freezer side seems to be working. However, the fridge side was experiencing some condensation and this morning the fridge side was warm. I removed the ice container and noticed the rear upper vent was...
it could have advanced to the defrost cycle, If you can unplug it for 12 hours and not lose all your food, Try that first, with the hotter months ice slowly builds up from the repeated open and closing of the door , once the defrost can catch up it should work ok
Jul 10, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
The refrigerator is not cooling properly. We have turned the setting to coldest and it is still too warm. The freezer seems to be working fine.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 08, 2011 | Refrigerators
Have a maytag french door fridge on top freezer on bottom, fridge is not staying cold, frezzer works just fine?
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils (under the unit) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both doors wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 04, 2011 | Maytag Refrigerators
Mtb1953he fridge not cooling before it stopped fridge was making loud popping noise, i unplugged it then plugged it back in a day later to unthaw and fridge worked for 2 weeks now not working again. there...
It sounds like your defrost circuit is having a problem. Once frost builds up on the coil in the freezer compartment, air can no longer be pulled though the fins and circulated into the fresh food compartment. You notice things start to warm up. Eventually, the freezer suffers from the same lack of circulation and contents begin to soften and melt.
The defrost circuit consists of 4 main parts. They are: 1) defrost heater, 2) defrost terminator or sensor in series with the heater, 3) defrost timer and 4) wiring between the previous 3 parts.
The defrost heater is found in the compartment that houses the coiling coil. The defrost terminator or sensor is clipped or otherwise secured to be kept in physical contact with the cooling coil itself. The defrost timer may be located anywhere the manufacturer decides - a popular spot is in the toe space on the bottom of the fridge. The wiring, well, that is between all the parts. Chances are the wiring is fine - as would be the connectors to the individual components.
The defrost timer runs about 8 hours. About 20 - 30 minutes in that 8 hour period the defrost switch operates. This consists of switching power away from the compressor (so it shuts off) and to the defrost heater and defrost terminator. The heater is just a relatively small value heater that warms the compartment to melt any frost or ice from the cooling coil fins. It will be powered for up to 20 - 30 minutes by the timer or less - if the defrost terminator senses a rising temperature on the coil. This means that the heater will be on for either 20 - 30 minute OR until the defrost terminator gets warm enough.
If the timer is stuck - and never moves to the 20 - 30 defrost cycle, the frost on the coil will never melt away. If the timer does work, but the heating element has failed, the frost will never melt away. If the defrost terminator has failed open (preventing the power from getting to the heater), the will not work to melt the frost off the coil. If there is a loose, missing or damaged connection between the wiring harness and these components, it won't run as expected either.
Make sure there is continuity through the heater. When cold (below freezing) the terminator should also have continuity. Many are designed to open around 50 degrees F - so if you warm it up, you should see the continuity go away. The timer needs power to run, and will send power to either the compressor or defrost heater - never both at the same time. Check with power disconnected. Use care checking live circuits - and only work live circuits when you need to check for presence of power - otherwise, unplug!
I hope this helps. Please rate this reply - thanks!
Jan 05, 2011 | Maytag MTB1953HE Top Freezer Refrigerator
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
My fridge clicking, buzzing and then clicking back off. Inside it was starting to warm up and was starting to leak water onto the floor. Today someone came out and replaced the relay. After 4 hours the...
Hello, no if the compressor is still running and you are not hearing the click you should be ok. It will take approx 8-10 hours for it to get to normal temp. The frost you mention on the freezer panel could be a problem with the defrost system. I would leave it over night and check it tomorrow. If there is a major ice build up comment back and i will assist you further. Mike
Oct 19, 2009 | Maytag Refrigerators
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Maytag wide by side
you're lucky, these fridge's are garbage!
Jul 08, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
77 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
