Question about HP Pavilion dv1000 Notebook
Hp paviliondv1331 runs for awhile and then dies
The laptop runs for a while and then it just dies. We have it pluged in and charged. Do you have any ideas what might be causeing this?
  • 45 Answers
It turns off to a black screen? It could be a hardware failure but it is also possible from a software corruption issue. Could you go to Control Panel>Computer Administration>Event Viewer. Click on System and you should see several errors that have a red "X" next to them. Double click the top error and post the result here.
Posted on Jul 08, 2008
Dell inspiron 1525 pluged in not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Dec 02, 2012 | Dell Inspiron 1525 Notebook
I have a dell 1737 that will not recognise any power adapters I plug into it. It runs fine on the mains through the adapters but will not charge the battery. The battery works fine on the laptop if I...
ok becare with pluging in any power adapters, coz the machine has to run with the correct voltage. otherwise it will cause alot of damage to your laptop
Oct 22, 2012 | Dell Studio 1737 Laptop
Issues with Laptop Battery not charging
You may have a bad battery but, my best guess is the motherboard and it is not cheap.
www.aaatvservice.com
May 09, 2012 | Dell Inspiron Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
I have a Dell XPS M1530 laptop and a few days ago I replaced the cmos battery and it worked; now it won´t but up. it started shutting down, now fan runs for 2 seconds lights come up but no display and...
Is it charging? If it isn't then try a different charger but reopen it and clean it with a soft brush and try again otherwise it looks like you've a PSU fault there and you have either disconnected or caused static damage to the system.
Sep 17, 2010 | Dell XPS M1530 Laptop
My laptop has problem, it is not indicates charging light and also not charging so it can't start should i replace battery ? how can i run my laptop on dirict pluged in plz, give me idea
Well It doesn't seem to me the problem of battry so replacing it is not a gud choice if you want to confirm that then take out the battry off your laptop Plug in the power pin and press the power button see if it start on direct pluging if it does then it must be your battry which requires a replacement and if does not than you power plugin socket needs to be reparied. Hopefully this would help...
Aug 22, 2010 | Acer TravelMate 4220AWLMi Notebook
Acer aspire 5315 batt problem
Please run this unit on A/C only and see if it powers up like that. If it does not, then the A/C adapter is faulty and thus cannot charge your battery.
Service the battery by hitting it flat onto your hand palm or onto the back of your shoe and retry to see if it is charging.
May 25, 2010 | Acer Aspire 5315 Notebook
My kodak M1063 digital camera was working great with no problem, my husband started useing it but the batterie was low and needed charging he didnt want to wait so he took out the batterie and put a...
The old used battery was probably not used for a long time and in time, completely discharged and died. It can't be brought back. I don't know why your camera won't turn on with the original battery.
Dec 23, 2009 | Kodak EASYSHARE M1063 Digital Camera
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
