Hoover Nextra 8
Hi!
Thanks for the tip. I thought I might elaborate on the problem before I touch anything.
It seems the machine is heating the water excessively to the point that steam comes out of the detergent drawer. This happens on all but 4 cycle settings. I thought it would be a problem with the thermostat maybe??
Thanks again!
Alex
  • rednaxela_76 Jul 10, 2008
    Hello again!
    I did some research and found a Hoover / Candy NTC Temp sensor:
    http://www.partmaster.co.uk/cgi-bin/prod...
    I pulled away the back panel and found the same part so I ordered the above and replaced it on my machine... ran a cycle and it's still boiling the water!
    Any other ideas? It will cost me £90 for a Hoover callout.
    Thanks again,
    Alex
  • rednaxela_76 Jul 12, 2008
    Hi D,
    Any idea how to locate the heating element on this particular washer-dryer?
    Having replaced the temp sensor I suspect a fault on the pcb which I
    assume would normally regulate the heating element and therefore the
    water temperature? I heard the pcb is one of the most expensive parts
    to replace. It might be worth the £90 call out charge after all??
    Once again thanks for your input!
    Alex
    Sergeant:
  • 225 Answers
Yes, it is beginning to sound like the thermostat has failed. They usually fail the other way - refusing to heat the water.
A thermostat is a simple little 50p / $1 item if only you can find it, identify it and fit another yourself.
If you have to buy one from a spares dealer, x15 !
If you have to get a repair man to visit, x200 !!
If I were faced with this problem on my machine (being reasonably techy) I would initially disconnect the machine from the power supply, find the thermostat and cut it's wire off in such a way that it could be joined again afterwards (insulating both ends). Most clothes can be washed quite well in cold water.
Hope this helps a bit. Cheers, D.
PS Be prepared for the machine to throw a tantrum or fault code after disconnecting the thermostat - if it won't work at all with the wire cut we'll have to think of a "Plan B"
Posted on Jul 06, 2008
  • Richard Raynor Jul 11, 2008
    Hi Alex,
    As an interim measure - if it were my machine - I would disconnect the heating element and insulate any bare wire ends.
    Something is clearly "stuck" on - with motors there is likely to be a triac controller but with a heating element it could be a simple relay. If you can find it on the circuit board and give it a gentle tap, it might free itself. You'll just need to trace the wires from the element to the pcb.
    Hope this helps ! Cheers, D.
  • Richard Raynor Jul 12, 2008
    The heating element - I suspect it is down at the bottom of the outer drum, where the water is ;-) You should see two or three terminals stcking out of the back of the drum. I'm not familiar with your model, so I can't say for sure.
    There is probably a relay on a pcb which may be stuck in the closed position and might release with a sharp tap. It may be worth extracting the pcb and checking it for burned tracks and other obvious signs of grief.
    Are you in the UK? - since you linked to a partsmaster.co.uk website you probably are.
    How old is your machine? A friend of mine is currently in "discussions" with Hotpoint, via his MEP and Trading Standards Office over a defective washine machine just 13 months old. The fact is that a two year guarantee applies for the sale of all consumer goods everywhere in the EU (Directive 1999/44/EC). Not many people seem to know this, least of all Hotpoint UK. And even under the Sale of Goods Act goods like washing machines are expected to be "durable" - and when asked our local Currys said durable meant 5 or 6 years. So there's another avenue for you if you like a scrap!
    Let me know what you think. Cheers, D
HI We have a Hoover 700LD washing machine that wont fill or wash. Will drain and spin. Any ideas? thanks
Thanks for choosing FixYa and welcome. You need to check your water inlet valve and make sure it is not defective. Check your water pump and make sure it is working right. The pump pumps the water into the washer.
Feb 05, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Hoover washing machine model HNF71683D not draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Washing machine not heating water
Washin machines "do not" have heating devices, make sure to check your water heater and turn it back on to get your water heated.
That will get you back in hot water business.
GOOD LUCK.
Aug 30, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Hoover washer dryer hnwf7167
this will be your carbon brushes this will only cost £15 at the most pull your washer out now tip it back so u can get under it the carbon brushes are fitted on each side by 2 screws there are only 2 carbon brushes on your motor
Jun 10, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Issue with Water Pressure
blocked dispenser box Regards Advisor
Aug 22, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Washing Machines Logo
289 people viewed this question
Top Washing Machines Experts
