Question about Dell Inspiron 4000 Notebook
CD/DVD drive stopped working gradually
The CD/DVD drive (front bay) I got with my Dell Inspiron 4000 laptop has gradually stopped working. The drive appears to plug in fine and receives power. I can open it and insert a cd or cd rom, and the drive starts to spin. But less than a second after I hear it start spinning it stops again and the disk is not read, let alone played. I can remove the disk fine. Help!
  • IvyRose Jul 06, 2008
    I tried this, but when I get to step 5 on the link page you sent, UpperFilters is not one of my choices in the right pane, nor in any subfolder of that long number/letter name folder.
  • 3,940 Answers
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article: http://support.microsoft.com/kb/314060
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Posted on Jul 06, 2008
  • IQUIT Jul 07, 2008
    If no upper filters, then go to the next step
My laptop is not recognizing the cd dvd; something about a bay
Go into the bios (F2 starting up most laptops) and make sure the bay is enabled.
Apr 19, 2010 | Dell Inspiron 2200 CD-RW/DVD Drive Combo -...
Hi, my problem on dell inspiron 1526 is this: SYSTEM MODULAR BAY cannot be indentified.... problem is that CD/dvd drive show signs of work(when i turn my computer on Green led blinks,motor starts to rotate...
If the drive functions in another system the the issue is either the motherboard contacts or the controller. Flash the BIOS to the most current version and reset the BIOS defaults. If the drive still doesn't detect, then a motherboard replacement is likely in order.
Nov 15, 2009 | Dell Inspiron 1526 Laptop
My Dell Inspiron's DVD has suddenly begun making a loud humming noise when I play a video? Why?
This is usually happens if the DVD drive receives too little power from the laptop or maybe it's just needs a cleaning.
I would try first to clean it from the inside, using a cleaning CD. If that doesn't help you will have to check maybe with a technician if the drive is receiving enough electricity.
Some info- Dell is known for her malfunctioning drives, mine sucks. It reads okay, but burns crappy CD+DVD. sometimes these drives needs to be replaced after a while
Oct 15, 2009 | Dell Inspiron 4000 Notebook
Dell Inspiron 8600 Cd RW/DVD has stopped working
this problem occurs when the lens of the drive gets weak or broken
you can either buy a new drive or just get the lens of the old drive replaced
yes its possible to replace a cd rw/ dvd drive with a dvd rw drive
Sep 29, 2009 | Dell Inspiron 8600 Notebook
INSPIRON 9400 DOESNT BOOT - BLACK SCREEN - PLS ADVISE
make sure there is no CD/DVD left in the drive bay when you boot your laptop. Remove usb flash drives also.
Regards!
Jul 17, 2009 | Dell Inspiron 9400 Notebook
Error code 1046: new hard drive, still problems
since the keyboard and dvd are on different controllers it may be the motherboard but then I have seen weird things when memory goes bad. I would download memtest on another computer and burn it to cd and run it from bootup and test the memory first. If not the memory then motherboard is a likely answer
Jun 29, 2009 | Dell Inspiron 2200 Notebook
My disc player on my computer doesnt open
I assume you have a CD/DVD jammed into the drive ...
Most CD/DVD drives have a small hole at the front .. carefully push in one arm of a paperclip (you may have to go in 10mm or so) .. the drawer will then release with the power off ...
Mar 12, 2009 | Dell SideBay/Fixed Bay DVD+CDRW Combo...
Ways to load OS
External Floppy disk drive or External CD/DVD drive. Might be easier to just replace the internal drive.
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Dell letitude c600 cd dvd rom problem
Most likely you need a CODEC
check shark007.net they have an extensive and clean CODEC pack, be careful downloading CODECS many are spyware infections
Jan 31, 2009 | Dell CDRW/DVD COMBO LATITUDE Inspiron CPI...
Dump of Physical Memory
Put the Dell CD in the drive bay. Turn on the computer and start pressing <F12> key. It should say "Preparing one-tome boot" When the screen shows a selection menu for the boot device, use the arrow keys to select the CD and press <Enter> key. That should run the Dell CD. Follow the onscreen prompts to run diagnostics checks
Dec 16, 2008 | Dell Inspiron 8600 Notebook
Dell Inspiron 4000 Notebook Logo
158 people viewed this question
Alun Cox
