Question about Mitsubishi WS-55819 55" Rear Projection Television
What next are these plug and play parts or will they require me to remove boards and soder parts. where can I order these parts? thank you so much for your help.
  • Mitsubishi Master
  • 8,617 Answers
No they will require soldering and unsoldering. I suggest that you go to the following link and order the service manual for your model, as they will email it and then help you for free with online instant messageing to diagnose it and then they have any part that you would require as well. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 06, 2008
Standby power failure
If warrantee still good get new one if not check for broken solder joint on transistor works until it gets hot may need new transistor should have numbers on it., If to hot will need schematic. first get sodering iron and soder 60/40 remove all covers, get(freeze it) a can of cold spray and keep hands away from power supply board the board with the wall plug coming out of it and the thick wires connected to it. do not touch, Plug it in the wall and wait until it turns off, spray the componets that you think are the problem the cold will allow it to turn on for a while check the transistors first (little black box with three leggs) then the capacitors (the little blue barrels with the black lines on them) when you find the componet call the company for the replacement part find the manufacturing company on the internet they will have it.simply make a drawing of the way the componet was in the curcuit and put the new one in,tip on how to soder pull the soder off the roll about five inches, Place the hot tip on the leg and the board wait a second and drop the soder on the hot tip for just one more second, letting a small amount melt off.do this on each leg remember that a transistor has a ground,a hot, and a base,The cap has only a positive and a negative.Good luck
Aug 26, 2012 | Denon AVR-2308 AV RECEIVER 220 Volts-19407
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
Gauges stopped working in mt 1997 dodge caravan
This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pin you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. Hope this help I have done several of them.
Nov 28, 2010 | 1997 Dodge Caravan
GUAGES WILL NOT WORK
Nov 21, 2010 | 1998 Dodge Caravan
Instrument panel not working but van still runs good
Nov 19, 2010 | 1996 Chrysler Town & Country
Dash board not working
To fix the dash going out try this. This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pins you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. Hope this helps I have done several of them.
Aug 17, 2010 | 1997 Plymouth Grand Voyager
My question is.My dodge`s dashboard sometimes doesnt work and bort computer.So is it a problem with fuses or something else? thank you
This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pins you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. Good luck
Mar 20, 2010 | 1999 Dodge Caravan
Gadges on intrument panel go off and on 98 dodge caravan
Nov 16, 2009 | 1998 Dodge Caravan
Flat Panel Emerson Tv lc32oem82s
Answer your first question. yes, it is the same part.
To help you with the second question I need some info.
1. Do you have a multimeter?
2. A sodering gun with new soder and soder removal braid?
3. Sodering skills on circuit boards?
Jan 26, 2009 | Emerson EWL3706 37 in. LCD Television
Abs light
To fix the dash going out try this. This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pins you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. This also may fix the ABS light. Hope this helps I have done several of them.
Sep 04, 2008 | 1995 Plymouth Grand Voyager
Mitsubishi WS-55819 55" Rear Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
