Question about Tasco Galaxsee 45-114375 375X (375 x 114.3mm) Telescope
Finderscope image upside down & not focused if viewing past 100 yards
I was trying to calibrate the finderscope and everything is upside down and unfocused (except for close onjects).
    Genius:
  • 1,027 Answers
The upside down image is normal for astronomical telescopes. The finder usually is a fixed focus, but it can be altered for various eye types, by rotating the objective lens for focus - the cell should move in or out on fine threads.
Posted on Jul 07, 2008
It is the first time that I have a telescope just want to now the finder scope why is it that if you look through it its upside down. Did I do something wrong or must it be like that?
It is normal with astro telescopes to show an image upside-down (and sometimes reversed as well). This is because stars (but not planets) look the same both ways. The finderscope is usually the same.
You can get correct-image finderscopes though
http://www.optcorp.com/ae-fre80bk-80mm-right-angle-image-correct-finderscope-black.html
and for the telescope itself you would fit an erect-image diagonal prism, either 45 deg or 90 deg.
http://www.optcorp.com/os-d125ei45-45-erect-image-diagonal-1-25inch.html
Dec 30, 2015 | Optics
What is the correct way to use the viewfinder?
It is normal for everything to look inverted in an astro telescope. If you was to use it to view terrestrial, you will need to fit an erect image diagonal between the focuser tube and the eyepiece, such as
This can still be used at night. The same is true for the small finder scope fitted to many telescopes. You can get a terrestrial type which can also still be used for planets etc
http://www.optcorp.com/tpo-8x50-right-angle-finderscope-and-bracket.html
Oct 10, 2015 | Optics
When I look through the view finder--everything is upside down???
Astro telescopes normally do show an inverted image, since for most purposes this does not matter. For terrestrial viewing, such as thru someone's window, you can buy an "erect image" or "correct image" prism which gives an upright image.
http://www.optcorp.com/telescope-accessories/optical-tube-accessories/diagonal-prism-eyepiece-holder.html?a_diagonal_design_f=1090
I don't know of such a thing for the finder scope, you would have to buy a new finder.
http://www.optcorp.com/celestron-9x50-illum-ra-correct-image-finderscope-93781.html
Mar 06, 2014 | Celestron NexStar 114GT (269 x 114mm)...
The finderscope is showing everything upside down
Astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear. It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one, but one wouldn't bother to do this with the small finder scope.
Jan 02, 2011 | Celestron AstroMaster 70 AZ (160 x 70mm)...
I purchased a Edu Science 70mm Astro-Gazer telescope for my son for Christmas and discovered that the finderscope that came with it is showing everything upside down. I returned it and the new telescope...
The main scope is probably also designed this way, but many amateur scopes now come with an erecting prism or eyepiece attachment that turns the image upright. You may have fitted this and not realise that it is an add-on, and that it is un-natural for an astronomical scope to display upright images.
Dec 29, 2010 | Edu-Science (10166) Telescope
Why is the finderscope showing the view upsidedown?
All astronomical telescopes show upside down images-- it's normal. There is no up or down in space. You can buy an "erecting" prism for terrestrial viewing.
Read my TIPS on my profile page.
Dec 13, 2010 | Tasco Novice 30060402 (402 x 60mm)...
Bushnell Discoverer 78-8945
All astronomical telescopes show upside down images. Read my Frequently Asked Questions Tip on my profile page. These scopes are made to view objects in the night sky which are very small, and faint. To erect the image would require more glass or mirrors in the optics and would further dim these objects.
You can buy an "erecting prism" to use for terrestrial viewing. Like this:
http://www.amazon.com/Bushnell-780103-1-25%C3%93-Format-Erecting/dp/B000EY2ZFK
Your scope is working just fine.
Jul 07, 2010 | Bushnell Discoverer 78-8945 (325 x 114mm)...
Everything is upside down! why? how do i fix it?
Astronomical telescopes show upside down images. No up or down in space. To invert the image would require more glass and or mirrors.
You can purchase an erecting prism to use in viewing terrestrial targets.
http://science.howstuffworks.com/telescope23.htm
Read my Frequently Asked Questions TIP on my profile page.
Mar 30, 2010 | Tasco Specialty 301051N (100 x 50mm)...
When i look in the finderscope the objects r upside down but when i look in the big one theres nothing,even when i try and zoom in and out thers nothing moving
Some finders show things upside down. There is no up or down in outer space.
During the daytime focus on an object like the top of a telephone pole a good distance away.
Without moving the telescope adjust the finder scope so that the "crosshairs" in the finder are centered on the same object as the main tube. Most astronomical telescopes show upside down and reversed images.
Nov 04, 2009 | Meade (r) TeleStar Manual 60mm Refractor...
When viewing everything is upside down.
Yes, all astronomical telescopes show images upside down. There is no up or down in space.
Sep 01, 2009 | National Geographic 76AZ (525 x 76mm)...
Optics Logo
407 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
