Question about Canon FAXPHONE L80 Laser
Fax line stays busy continously...
Took out the fax machine, which works fine, put in the l80,plugged into the "L" telephone slot, now the line rings or stays busy continuously, help The fax is saying "line in use" - but the phone line is fine.
  • nickand99 Jul 09, 2008
    Hi to all,
    Model Canon L80
    TX - I have the same problem I have a Canon L80 and phone line is well attached to it and each time I want to send a fax it drop into a fast busy tone after scanning the first page.
    RX- When I am calling the fax device it does not want to answer same if I attach or not a phone device to it. Fax does not want to pick up the line
  • Canon Master
  • 2,794 Answers
Are there any other phones that use that line? If you have a phone attached to the fax machine, is the reciever in the holster all the way?
Posted on Jul 06, 2008
Nothing can be faxed.It keeps auto redailing.
Check for a dial-tone with a regular phone.
Sep 25, 2009 | Canon FAXPHONE L80 Laser
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Cannot receive faxes
Make sure that the telephone line from the wall is plugged into "LINE" and not "PHONE" on the fax machine. You might also call the fax number from a different phone to see if you can hear the fax tones.
Aug 20, 2009 | Canon FAXPHONE L80 Laser
HP Officejet Pro L7680 shows "Phone off hook"
scroll through the menu of the machine and come to the fax settings and then and chck if the line in use is line 1 or not,the DRP is set properly according to your telephone service provider,you have the phone line connected to line 1 port of the machine,you are not using a digital line for the fax machine,if you have a TAM then set the printer to picj\k up fax calls at two more rings than your telephone.
if you want a technician to do the entire troubleshooting for you.You may get in touch with one of the techbuddies,they offer free technical support for such issues.
you may get them at http://tinyurl.com/m7ghqz
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Canon Faxphone L80 - Alan Silva
To send a fax you do not need to enter anything into your fax. You have to make sure that you connect the telephone line to it's desgnated connector. You dial a number to send as if you are calling form a normal phone. If you ever get a ringing tone press start. You can enter any data trough the data registration after you make sure your fax is functioning properly.
Jun 24, 2008 | Canon FAXPHONE L80 Laser
Want to hear a message being recorded
okay, best thing to do is start from scratch, plug the phone line from the wall to the slot marked by the " L " on your fax, then pug the other phone into the slot marked with "phone" and listen for a dial tone. you should be getting if so then your fax should be working. hope this helps, if this doesn't fix it then let me know so i can better help you.
Thank You,
Mikey
Mar 10, 2008 | Canon FAXPHONE L80 Laser
Can't receive faxes
Something is causing the fax machine to "trip" to busy. There is some type of short occuring either in the fax machine or the physical phone line itself. Unplug the fax, plug in a regular single line telephone. Call the fax number from another telephone. If the phone rings and you can talk to the other party, the problem is in your fax machine. If the call still is busy, the problem is in your wiring, either in your office or the phone company network.
Feb 01, 2008 | Canon FAXPHONE L80 Laser
Canon Fax phone L80
If it is a dedicated fax line it is probabaly best set to fax only mode. Fewer rings (No more than two) FaxTel mode will ring for longer to allow you to pick it up if its a phone call.
Check if the machine has dial tone by onhook button or handset to check. If you have none try testing with another phone to rule out the machine.
Try a manual reception. Pick up the phone when it rings and press the start button.
Jan 31, 2008 | Canon FAXPHONE L80 Laser
Still a problem? Can you be more specific?
Jan 29, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
394 people viewed this question
old marine
old marine
