Question about Canon ZR100 Mini DV Digital Camcorder
Canon ZR100 cassette compartment won't open
I have a Canon ZR100. When I slide the eject button, I am able to open the outer casing without difficulty. However, the inside black and silver compartment will not open. There is no tape inside. The camera powers on without difficulty. There is no sound of motors whirring or anything. Is there a way to open this thing, or a dismantling guide somewhere?
Thank you,
~Kim
  • 1 more comment
  • kimdembrosky Jul 06, 2008
    Hi Bubbabear,
    Even if the camcorder is plugged in, there is no sound if I try to eject it. The camcorder will turn on, however. Could it be the smaller, watch-type battery needs replacing?
    Hi!
    That makes sense. I tried opening the plastic door as far as I could. It does seem to be open as much as it's supposed to be, however, nothing happens. This mechanism...which side of the lid is it on? Is it something I could poke at with something to get it to open? (I'm all for dismantling this thing if I need to)
    ~Kim
    Ok, thank you for the suggestions. I'll see what they can do.
    ~Kim
Ok so my tape inside broke and i spent some time tinkering around with it.
step 1: take the extremely small screw out from the top. VERY SMAL!!! hehe
step 2: with some strength behind it, try to slide the cover that the screw held on off the top and thatlets the cassette tray come out...
now when i put a new cassette in, it will close, but will eject it after it thinks if it will accept the tape or not... i think its just being retarded... tried the tapping thing - didnt work... im thinking of dropping it out the second floor and trying afterwards...
Posted on Aug 19, 2008
  • Canon Master
  • 2,794 Answers
Usually a chime happens when you open the plastic cover just before it opens. If you plug it into the electrical outlet does it eject that way?
Posted on Jul 06, 2008
  • Tim Babcock
    Tim Babcock Jul 06, 2008
    The watch battery is only used for the date and time.
    I know Cannon is tight about releasing the service manuals for this but I have an idea.
    The eject mechanism is engage by a switch located in the lower hinge section of the lid.
    What happens if you pull the plastic door back further?
  • Tim Babcock
    Looks like its built into the hinge. If you rock it back and forth you should be able to feel the resistance. If there isn't any resistance it probably wont engage.
    You could try taking it to Best Buy and see if the Geek Squad will have a quick fix for it.
Everytime I put a cassette into it, it always says to eject or remove cassette, why is this?
Most of the time this happens is when the tape in in the save mode. check to see if this is the case before inserting.
Feb 07, 2011 | Canon ZR100 Mini DV Digital Camcorder
Can not eject
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 11, 2009 | Sony Handycam CCD-TRV318 Camcorder
The cassette is stuck and the player will not eject it. when you turn it on it just makes a beeping noise.
Aug 11, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Canon md101 manula eject
yup there is sort of... you take a jewelers flathead screwdriver and push the spring back on the lens side of the cassette holder. and then on the other side there is a little hook that latches over a bump that locks it in place, you push that down and it will unlock... from there you might have to take the extremely small screw out at the top and remove the whole cassette tray...
Jun 09, 2008 | Canon ZR100 Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds.
Sep 04, 2005 | Canon Optura 400 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
517 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
