Question about Panasonic Televison & Video
Panasonic dmr-hs2 dvd recorder / player disc stuck in door will not open
  • 497 Answers
Try opening the cabinet and release the friction
Thanks for using Fixya
Posted on Jul 06, 2008
I want to reset the reorder but i don't know how.
If you do not have your original instruction manual, you can download a free pdf from:
(right-click and save link/target as... - it is a 3.2MB file (total size))
It may or may not help. Either way it's free.
Apr 25, 2011 | Panasonic DMR-HS2 DVD Recorder
On switching on, has single circle spins with dvd led
I had a similar problem with an RCA DVD recorder and I had to replace a capacitor inside the machine.
Jan 16, 2010 | Panasonic DMR-HS2 DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
    I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
    tried unplugging HDD...still does it.
    Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
    Won't recognise DVD Ram and non-finalised discs from own recordings.
    Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
    Hope this be of initial help/idea. Pls post back how things turned up or should you
    need additional information.
    Good luck and kind regards.
    Thank you for using FixYa..
    May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
    DVD Disc Drive
    So farit seems that the laser lense or the laser coil is bad. I found my lense chipped. One site indicated this is because of the use of "bad" DISCs that cause the laser diode to overload because of repeated attempts to read the bad disk. The coil and/or diod get hot and burn. I don't know how my lense got chipped!?
    May 01, 2008 | Panasonic DMR-HS2 DVD Recorder
    Panasonic DMR-HS2 DVD door won't open
    dvd player just keeps on loading
    Apr 15, 2008 | Televison & Video
    Locked DVD Tray
    I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
    With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
    If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
    Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
    Dvd model DMR-E55
    IC001 STRG6353 on power board may be faulty, mentioned also in several other threads.
    Available from various suppliers.
    Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
    Panasonic DMR-E50 won't recognise blank DVD's only
    You can only record to dvd-ram or dvd-r NOT dvd-rw!
    Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
    Televison & Video Logo
    56 people viewed this question
    Top Panasonic Televison & Video Experts
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
