Question about Sewing Machines
Re-engage clutch Necchi 3205FA?
After winding the bobbin on my brand new machine for the first time, when I go to sew, the hand wheel clutch spins but the stop clutch knob doesn't. I've played with all the tensions and tightened the stop clutch knob until I have blisters. Nothing. It's like the clutch doesn't re-engage.
  • 1 more comment
  • marinermama Jul 07, 2008
    That did it!! Thank you!
    Thank you!! It worked!!!
  • kab_271 Sep 19, 2008
    we took the screw off but we cant get the wheel to come off
2 Suggested Answers
  • 980 Answers
SOURCE: I have a Necchi Royal Series 3205FA. I wanted to
If you have a stop motion dial with little grooves all the way round the best way is to get a wide plade screwdriver, put the plade part on one of the grooves on the left hand side of the dial and give it a thump on top with your hand, that usually does the trick.
Posted on Mar 07, 2010
My Necchi sewing machine-model #534FB will not sew.
perhaps the hand wheel clutch need tightened .
Mar 03, 2018 | Necchi Sewing Machines
How do I wind a bobbin?
Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Necchi bobbin wind Google Search
Oct 17, 2016 | Necchi 3101 Mechanical Sewing Machine
The foot pedal is not moving the machine but still makes a noise
A: You said, "The your foot pedal is not moving the machine, but still makes a noise". . . . I'd suggest checking if the sewing machine has a disengaged or broken drive belt, gear or linkage; if not the problem, may just be that the Hand-Wheel clutch mechanism (on the left center of the Hand Wheel) is in the Bobbin-Winding position. If so, it allows the machine to cycle, operating the Bobbin-Winder without the needle moving up or down. Older Brother machines, like many other brands, used a large flat shiny Screw Knob in the center of the Hand Wheel to engage or disengage the Bobbin-Winding feature, newer models use a plastic teeter-totter switch located in the same place, to do the same thing. Keep tinkering, you'll will resolve it.
Sincerely,
-- Amender (2016 FEB 23)
Feb 03, 2016 | Brother Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
Why won't my necchi wheel engage
Is the bobbin winding mechanism engaged? If so, it may disengage the wheel. I have a machine that does that.
May 22, 2014 | Necchi Sewing Machines
Ned a diagram (or detailed instructions) on to thread a Necchi 3205FA & installing the bobbin. Thanks.
try www.sewusa.com there are threading diagrams for some Necchi models. even if yours isnt there the bobbin should be similar.
Sep 20, 2011 | Necchi 3101 Mechanical Sewing Machine
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I think a thread got stuck in the bobbin area....and now the needle won't pick up the bottom thread.......
Make sure you clean all the broken thread out of the bobbin area first. It sounds like you knocked the timing out when the thread knotted up. Look in your machines manual on the procedure to re-engage the timing. It will probably be a push this button in while turning the hand wheel until you feel the clutch re-engage, type of procedure.
Good Luck!
Chris
glfi.com
Feb 11, 2011 | Necchi 4575 Mechanical Sewing Machine
I have a Necchi Royal Series 3205FA. I wanted to wind my bobbin. I could not loosen the Stop Clutch Knob. This is a NEW sewing machine. It isn't a strength problem. The part will not turn.
Feb 21, 2010 | Sewing Machines
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
174 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
