I have a studio series model # 42hd43b tv hardly ever use it, but now it won't turn on. it is plugged in. the outlet has power.I have unplugged it and let it sit for awhile then plugged it back in but still no go. I have used the on button on the unit and the remote (which lights up when presed)still no go . Thanks nborzek@comcast.net
5 Suggested Answers
TVtechmaniac
  • 140 Answers
SOURCE: won't power up
This model has had problems with the keyboard buttons on the front panel,causing them not to work and canceling out the remote operation. To verify this,you need to remove the front panel so you can access the connector on the keyboard pc board and unplug the connector.After doing this,see if the remote control is able to turn on the tv (wait for it to power up because with the connector off, the green power light will be disconnected and will not light up when the tv is on) If the tv works, than you will need to change the ten individual switches on the board - part# 432P089010 (or just use the remote only)
Posted on Aug 21, 2007
  • 1694 Answers
SOURCE: TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
www.Chris@ChrisAndNat.com.................T.
Posted on Nov 23, 2007
SOURCE: mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Posted on Nov 27, 2008
Slinteriors
  • 8617 Answers
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Posted on Jul 18, 2009
SOURCE: Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Posted on Aug 13, 2009
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Tcl model 21k77
Try turnning your tv off, unplug unit from outlet, press and hold down the power button for 30 seconds, let go of power button, if plugged into surge protector try wall outlet, if plugged into wall outlet try a different outlet, power tv on using power button on tv. Did you have a storm in you're area?
Jul 24, 2013 | Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
The TV won't turn on. No power at the unit. Tried different outlets with no change
ensure that there is power in the mains, then if power is present then unplug the cable and check the cable plug if the fuse is burnt and replace. if this still does not solve your problem then you can open the tv cover carefully and be cautious as the tv may have not discharged fully. check the ``power in`` fuse and measure its continuity, measure the rectifying diodes and ensure all are healthy also check the power ic which should be STR series for that matter. by doing this your problem will have been solved
Sep 21, 2011 | LG 47LH50 47 in. HDTV LCD
Who is liable for s replacement tv if electrical company turns power off and on during a storm and the tv won't come back on?
have you unpluged the power from the tv and the outlet for a few minutes? then plugged it back in?
Jul 25, 2011 | Sanyo Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Sanyo mode...
Hello
You just try one the procedure given below. One amoung will lead you to its service mode.
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Dec 16, 2010 | Televison & Video
Magnavox 19MD358D experienced a power surge, will not turn on. What are the steps to troubleshoot?
The Maganvox TV was still under warranty, I called 1-800-705-2000 and talked with a TV Tech. He instructed me to unplug the TV for one minute. This is called a "hard-reset". I waited for one minute, plugged the TV directly into the outlet, turned the TV on and it worked.
The reason I plugged the TV directly into the outlet and not the power strip, is because I think the fuse burned out in the power-strip.
Nov 07, 2009 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
