Question about GPS
I have a frunuo 1722C it started off that the gps ant wood not pick me up at my port it had me in my back yard . i put a new frunuo ant on now it picks me up but i did something on my plotter and now i lost all my marking (bouys) help!! thank you sergio larocca
Maanita
  • 1142 Answers
SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Posted on Sep 02, 2008
Harleyknut
  • 83 Answers
SOURCE: Garmin GPS 12 seems to be a few hundred yards out!
Go into your device and pull up the setup section. There should be a selection that needs to be checked called WAAS. When that is selected your accuracy should be +- 3 meters if I remember correctly. At any rate it will be much more accurate.
Posted on Apr 02, 2009
RPFinney
  • 385 Answers
SOURCE: 305 Not Picking up satellite signal
Visit the link below to update the software,
Here
Serial to usb connector needed like this Here
Should be good after that.
Regards.
Posted on Apr 16, 2009
  • 4090 Answers
SOURCE: My TomTom XL1 at times will not pick up gps
your battery is beginning to fade. if you fully charge it before use asnd it does this regularly then replace the battery
Posted on Jul 26, 2009
jonniewalker
  • 1031 Answers
SOURCE: my tom tom has lost gps help!
here are some tips on what to do ,To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays grey and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal
  • The GPS signal was lost sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after travelling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full colour and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster. Flight mode
On devices with built-in GPRS connectivity, flight mode also disables your device’s GPS reception.
To switch flight mode off, tap Flight mode in the preferences menu and then select Restore connections.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Reset your device
Reset your TomTom device. Click here to learn how to reset your device.
Install the latest application
We recommend always having the latest version of our application installed on your device.
Posted on Aug 28, 2009
Testimonial: "Thank you - it is working now! "
Skycaddie won't boot on the course
Go back and sync your courses and check your yards settings.
May 18, 2014 | SkyGolf SkyCaddie SGX GPS Receiver
I need to buy some Termite/Carp ant killer. How much will it cost me?
Thecost really depends on the of the bottle. If you just need it for homeuse, you can get a smaller quantity. This site has many termite/carp ant killerproducts, check it out http://www.nextag.com/carpenter-ant-termite-killer/compare-html
Jul 17, 2012 | Bonide Termite/Carp. Ant Killer Conc. 1...
How to dismantle a semi trailer with a wooden floor
Maybe use a grinder to grind off the heads of the bolts. Keep a fire extingisher handy because of all the heat produced from grinding. It may help to water down the wood first. After you get the boards off you can always grind the bolts off if you want to put new wood on.
Jan 06, 2012 | Cars & Trucks
The batteries died on my gps and after I put it on charge it does not turn back on? Is it dead??? What is wrong with it?? Why is it not turning back on?
hi fraserss
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Jan 24, 2011 | Magellan Maestro 3140 GPS Devices
hi fraserss
Bill
DOES NOT PICK UP THE SATELITTE SIGNAL
Sorry but you most likely have a major component failure in the GPS + ANT on the motherboard. If the unit is under warranty send to Magellan.
Oct 03, 2010 | Magellan Triton 400 Handheld GPS Receiver
Igo sat nav cant get gps signal ,it was working fine untill november 2009,now it does not pick up gps signal
The mosdt common reason for non connection is low battery power. The battery lasts approx 2 years and may not be charging correctly. Try changing to a new battery.
Second reason is that it is not on the right port, consult manual for your model and set it to its correct port and BAUD rate.
Finally if you have started the enginbe with it connected to the 12v car outlet you may have damaged the chip.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Navigon GPS MobileNavigator 5 Base Car GPS...
My tom tom ONe cannot get a valid Satelite Signal just stays wait
If you are indoors then move outdoors to get a signal.
If you are outdoors then move your location by a few yards and sometimes it will suddenly aquire the satellites.
Happens occasionally with my unit. I normally set a route up then start driving and it suddenly starts to work OK.
HTH
Peter
Mar 07, 2009 | Tomtom ONE GPS Receiver
Cant install Garmin Connect software
reboot the computer in safe mode. (HIT F8 during the startup) then after the computer loads put the ANT stick in the USB slot and it will then be recognized.
remove it and then reboot normally. Now simply reinsert the ANT stick after starting the ANT agent.
worked like a charm
enjoy
Dec 03, 2008 | Garmin Forerunner 405 Handheld GPS...
S620 Using GPS with Memory Map software
In the Comm Manager, select Settings, then Bluetooth.  Again select bluetooth and then scroll down to your GPS receiver assuming you're paired correctly.  Click Menu and then COM ports.  Now click Menu and select New Outgoing Port.  Pick COM6 assuming you have nothing else on this as your outgoing port.                   Now go back to your map program.  In the GPS settings, select COM6 as your GPS and it should now give your position.  I use google maps and have no bother.
Aug 19, 2008 | HTC S620 Smartphone
GPS Logo
27 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
