Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
No picture When I turn on my t.v. there is no picture but I hear sound. It is the fuzzy static sound. The power indicator light is on a well.
  • 927 Answers
Good Day;
Try resetting the TV by unplugging from the wall A/C outlet for 3 to 5 minutes, plug back in. No fix? Your TV's LAMP needs to be replaced. Part number; UX21516, for Model 55VG825.
Good Luck, big IRISH.
Posted on Sep 06, 2008
37' lcd sanyo. sound no picture. no backlight. when turned on screen will flash on for a second, power indicator light stays on . Hear electric static sound when screen flashes
Check the lamps connectors on the backlight inverter board make sure they are not loose. You may be ahving failing inverter board itself.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 22, 2010 | Sanyo DP37647 37 in. LCD TV
No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: http://www.discount-merchant.com/Mitsubishi-915P049010-Lamp-Replacement-p/mitsubishi-915p049010-lamp.htmHave a blessed one!
May 03, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Watching a TV program and during the program it just turned off. When turning back on TV, the light indicating that it's on but no picture not even static on the screen......just blank. Its a RCA Model...
Can you hear any audio? Look behind the TV, you should see some light emitted from a grill back there. If you hear audio and it appears you can change channels and what not, you lost at the very least your back light, which can be replaced , or worse the power supply to the back light which will cost you a bit more than the already expensive backlight.
Oct 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
Samsung Model HLP5063wx/xaa
what are the indicator leds on the front doing? if all 3 leds are blinking then it's probably the color wheel ,lamp or the dmd board, if you turn it on and it goes through a series of shut downs then the leds blink, it's probably the lamp or dmd board.
Sep 02, 2008 | Televison & Video
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
No picture but noice
Its possibly a defective vertical output IC as that can cause the picture tubes to blank out and volume will audio will remain.
Jul 06, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
