Samsung DVD-R128 recorder will not recognise DVD-RW disks even those that it recorded some time ago.Gives error message "This disk cannot be played,please check the disk" It plays commercial audio and video disks.
  • MorkyOrky Feb 23, 2009
    I have the same problem as terrycarse's ie my Samsung DVD-R128 does not reconise the blank DVD-R. I have installed a blank DVD-R into my Samsung -R128 to record. According to the manual it can record DVD-R discs. It prompts "Load" and according to the instructions the Load sign disappears and then you can record but I get a message that states "The disc cannot be played. Please check the disc" The DVD then ejects. It does this with all the new discs that I put in. Can you help?
  • Anonymous Mar 16, 2009
    Me too!
I have purchased dvd box set of day 7 of 24,but dvd player needs parental restriction password! dvd plays fine on my computer.
Posted on Mar 10, 2010
I have the same recorder. Have you tried sony discs? They work fine for me when other brands dont.
Posted on Nov 06, 2009
RC689 DVD recorder/vcr player not recognising blank disks
Take the recorder back, it is clear this is a manufacture issue.
Mar 28, 2012 | LG Televison & Video
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba D-R560KU Fails to record. Error message E-21 E-4 E-4 54037380 Time Schedual starts then fails almost immediately. Using Sony DVD+/-RW disks. Tried from new disks from several different stores.
I read your return email solicitation to me to pay you before any indication that you even have a clue as to how to solve my problem nor even a guarentee should you not be able to. My solution is to block any further emails from your bogus service.
Apr 14, 2009 | Televison & Video
Playing recorded DVDs on PC or other DVD player
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd is unable to read disk that i recoreded on the lg dvd recorder
It would be nothing to do with the TV.
DVD RW discs only last for so long if you have re-written to them many times they may be just worn out. Or is it with all RW discs?
Are you trying to watch them on the same player you recorded them on or is it a different DVD Player you are trying to watch them on?
Feb 17, 2008 | Televison & Video
Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
Dec 18, 2007 | Plextor PX-740A (00765075107763) DVD RW...
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Televison & Video Logo
637 people viewed this question
Top Televison & Video Experts
