Question about Masterbuilt SBMPG3 Veranda Steel Grill
Won't ignite The gas does not seem to be getting through to the burner. When the valve is turned on you can here the usual sound but there is no smell of gas (I even replaced the fuel tank with a new full one) and the spark is there but nothing ignites. Even when I tried lighting with a match...nothing. Could the regulator be the issue? There also had been some pretty heavy rains the last couple of weeks since I last used the grill. Any suggestions?
Replace the regulater
Posted on Mar 12, 2009
Why won't the burners light even when I smell gas and hear igniter clicking?
Bill, two things possibly going on here that are common with an aging grill. First you need to turn off the fuel tank and set it aside. you mention that a clicking can be heard when pushing the igniter button which usually indicates good battery but if you have never changed it you may want to just as a good measure. Unscrew the bottom and you should find AA or AAA battery behind it. Now with battery good and the igniter generating a fast load clicking sound you want to get down and follow the wire that runs from the the back side of the igniter push button down inside and usually under the burner tubes ending out at one end of each burner. What happens when you press the igniter switch is, an electrical current is sent down the wire and when it reaches the end the current jumps to the closest metal it can find creating a spark.so you need to insure that the end of the wire is close to where the flame is generated but not so close that that you cant see a spark. Make sure the end of the wire is bare and clean as is the area on the burner where it arcs Now do this to all for burners. Turn all the knobs on the grill off and connect the tank. Make sure the lid is open now, and slowly open the valve on the tank. I say slowly like a ten count from close to full open. what can happen if you crank the tank valve open too quickly or with the grills valves open a vapor-lock effect can be created greatly reducing the flow of fuel from the tank. Iv'e seen many of the uninformed return 1/2 full tanks due to this problem. If you notice week flame or no flame but smell gas ALWAYS SHUT OFF VALVE ON TANK IMMEDIATELY KEEP LID OPEN AND LET THE AREA VENT BEFORE TRYING AGAIN lest you be the one being barbecued. Good Luck
Apr 27, 2014 | Kenmore 16225 Grill
I can't get my Q to start properly. My start routine is to open the tank valve (20 Lb. with adapter hose) turn the control valve to start and hit the electronic start button. I get an immediate start at...
Yes, it does sound like a regulator problem or clogged burners, which causes delayed ignition.
let's start with the regulator first. Turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is fully open, light the burner(s) as you usually do. Does the burner light, all the way around? If so, you solved the problem. Always, turn the tank valve on very, very slowly.
If that didn't solve the problem, you burner needs to be removed and thoroughly cleaned, including the venturi valve at the open end of the burner. If it still doesn't light as it should, the regulator needs to be replaced. If necessary, you can purchase it directly from Weber.
Hope this helps you to troubleshoot and solve the problem. Happy Grilling!!
Apr 23, 2011 | Weber Q Grill
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Our grill doesnt seem to be getting enough gas to stay lit. when you turn the burners on your hear the gas coming through for 2 seconds..then nothing, and it wont stay lit
How are you turning the grill on and off? It sounds like a vapor-lock. Try this: first unhook the regulator and crack the valve on the tank open...if you hear and smell gas coming out, good, close the valve and re-connect the regulator then open the gas valve then turn the burner on and light it...then shut it off by closing the tank valve first and let the burners go out then turn off your burner valves...try that and let me know what happens.
Sep 06, 2009 | Grilling
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Amana oven gas leak issue
staunch has no idea what he is talking about. It has nothing to do with the igniter, or it would fire up at all. Since you are saying that your oven does ignite and heat up, it is the internal gas valve that is the problem.
The way all recent (20 year at least) are designed, the gas valve internally can not open unless the igniter is working, for obvious reasons ... boom! The igniter circuit allows the gas valve to open, once it detects that the igniter is ready to "ignite" a gas flow. BUT, the valve can be bad in the AMOUNT of gas being delivered. Your's is allowing too much gas, more than can be burned, hence the smell.
DON'T use the oven until you have a qualitifed tech come out and replace the valve. It is very dangerous for you to do it yourself.
Nov 22, 2007 | Kitchen Ranges
Masterbuilt SBMPG3 Veranda Steel Grill Logo
333 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
