Question about Maytag M7DH65B2A Dehumidifier
Replacement float I need a new float. Where and how do I order one? The tip had been repaired and then one of the tabs was broken off the side. So now my dehumidifier is not working. Thanks \ Dave
  • Anonymous Aug 18, 2008
    float is broken
  • Maytag Master
  • 5,568 Answers
There are number of reliable parts supply companies on the web;
is one I have used personally.
Posted on Jul 06, 2008
I have the same problem and need 2 new floats.
Please contact me at
Thank you.
Posted on May 05, 2009
  • 3 Answers shows this as part number 1025985 and states that it is discontinued with no other sources available.
Posted on Jul 21, 2008
  • Walt Kienzle Aug 20, 2015
    I found the switch that the float triggers and taped it to always stay on. Then I put on the hose attachment to direct the condensate directly to a drain and eliminate the need for the bucket.
The float is broken in our dehumidifier, is it repairable?
Is the float in the empty or full position?? If it is in the empty position, and the unit will run normally, then yes you can. The water will divert from the evap tray right into the hose. If it is stuck in the full position, and wont run because it thinks it's full, you will have to find a way to put and hold it in the empty position.
Nov 10, 2013 | Danby DDR600R Silhouette Dehumidifier
How do I open the remote control to replace batteries for this 5304476181 remote?
Turn the remote upside down. On the bottom (end away from the front), there is a small cover and the cover has a small tab on one side. Squeeze the tab and pull the battery tray out. The replacement battery is a CR2025. Put the new battery in with the + sign facing up (exposed). Reinsert the battery tray and push all the way in until it clicks.
May 22, 2013 | Sears Parts Direct Remote Control -...
Fill light on and beeps but holding tank is empty
If it is like mine, the plastic part attached to the float in the collection bucket is broken and no longer actuates the switch that indicates the collection bucket (holding tank) is full. When I checked several years ago, the replacement part was no longer available. I used tape to keep the switch in the position that allowed the dehumidifier to operate and attached the hose connector to allow the condensate to drain. The collection bucket isn't needed anymore with this arrangement.
Oct 24, 2012 | Maytag M7DH65B2A Dehumidifier
Dehumidifier Does Not Shut Off
Switch it off when you go out. Find replacement float switch
May 15, 2012 | Dehumidifiers
The float is broken
If all you need is the Styrofoam float, you're in business, If it's the entire float arm you're not so lucky.
See ref numbers
Sep 20, 2011 | Fedders A7DH45B2A Dehumidifier
its the bucket switch on the unit thats bad,it controls the water level overflow so unit shuts off when bucket is full,its at the top rigt side of the bucket mounted to the float in the bucket and there is a replacement available part # AP3136674,on some units depending on the mounting hole size,you may need to use some old switch mounting parts on the new switch so it fits
Apr 10, 2011 | Goldstar DH504EL Dehumidifier
Need water bucket and floater for Model m7dh45b2a cannot find replacement parts all that I need is a water bucket and floater
I have one that I just moved to my garage to junk out. My bucket and float is next to new. Email me at to hook up.
Aug 08, 2009 | Maytag M7DH65B2A Dehumidifier
Pump failure
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. Repair steps are as follows:
1. Remove the overflow water tank and the two side covers (five screws in each). Note that as you go through the removal of all the covers and other procedures, there are two lengths of screws; don't switch them. If you lose track, the rule of thumb is use the short screws for going through a single layer of plastic into metal.
2. Remove the rear cover (take out the screws along the bottom and on the sides). It will still be attached to the front top cover at the top with tab fasteners. Gently pull out the bottom of the cover while depressing the top of it on both sides with your thumbs (about an inch and a half inside the trim ridges) to clear the tabs. Ease the top part of the cover back and remove it (it will have to tilt to one side, don't forget this when putting it back on).
3. Remove the top cover, not forgetting the two screws on top by where the back cover attached (go gently, there's a wiring harness) and turn it to the side. There was enough slack to leave the wires connected; just be careful to not damage them.
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a wire tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
4. Remove the float and bracket from the pump reservoir. The reservoir screws are not all apparent; there's also a screw way over on the left and one coming in from the right. I used a 12 inch #2 phillips screwdriver with a magnetized tip for most of this. Remove the pump reservoir and clean out the scummy stuff in the bottom and where the tubes attach. When removing the reservoir, you'll have to detach the vent line that goes through the bulkhead to where the big tank was and pull the tab above it down slightly while easing the tank out.
5. Clean out any dirty tubes, paying particular attention to the coupling for the drain hose and the long drain hose itself.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again.
7. Depending on your confidence level, at this point you may want to plug in the dehumidfier, put the overflow tank in, turn it on, turn on the pump, and fill the pump reservoir to check for functioning and leaks. If you do this, just remember that the circuits are hot and not all are insulated.
8. If all is OK, unplug the dehumidifier and put the covers back on. Total time was about an hour.
Jun 26, 2008 | DeLonghi DE500 Dehumidifier
Broken shut off lever
I saw a website that had parts.
Looks like the float with the plastic tab was $7.99.
Jun 07, 2008 | Kenmore Dehumidifiers
Ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
May 21, 2008 | Goldstar DH304 Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
575 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
