Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
All igniters sparking
The igniters on all 5 burners started sparking on their own. We had to turn off the circuit breaker to stop the igniters from firing
  • 6 more comments
  • mspangler Aug 03, 2008
    All ignitors ignited simutaneously when Jenn-Air stove not being used causing a fire! Repairman replaced ignitor switch with Whirlpool brand. Ignitor's had to be replaced too.
    We have a Maytag dishwasher which Maytag informed us was a dire hazard & sent part, but never installed! We've had the part for 6 months! Beware Maytag/Jenn-Air quality.
  • thumper13 Aug 20, 2008
    we have all four ignitor's sparking after cleaning stove. We have unplugged the stove to stop. Any suggestions on how to fix?
    Jenn Air gas electric grill range model seg196C
  • Anonymous Oct 09, 2008
    Beware! The problem comes from water. If you get water, even a little that is what happens. We have actually had the ignitors catch on fire not once but twice in three years. Not a good design.
  • bethallynb Nov 02, 2008
    The stove in my case was not wet, nor had it just been cleaned. Had been operating normally, then out the the blue, in the evening started trying to ignite all five burners without units being turned on. Am trying to research this to see if I can fix it myself---
  • Anonymous Nov 30, 2008
    Same problem. All ignitors constantly firing.
  • Anonymous Apr 05, 2009
    jenn air gas range igniter wont turn off unless gas is turned on.
  • beanzcarlson Apr 17, 2009
    I cleaned my stove top was careful not to get cleaning solution in the burners about a half hour later all 5 burners ingnitions started firing and I could not stop them had to turn off the circut breaker
  • dezclark May 25, 2009
    all five burners are igniting
    Sergeant:
    Champion:
  • 330 Answers
The only thing which I found is after I clean the burners, maybe some dirt in.
Posted on Jul 06, 2008
Whirlpool Gas Range Oven will not start (gas flows, but no spark)
The ignitor does 2 things. It creates the spark for ignition and it signals the control the burner is lit(flame sensor). If the ignitor and wire are new the spark module is bad. If all spark components have been replaced then I would be searching for a poor ground wire. Are you by any chance using a GFCI circuit? Not recommended and if it worked on this type of circuit you were just plain lucky.
Eric
Oct 31, 2009 | Kitchen Ranges
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Kenmore elite dual fuel range top ignitors clicking like lite mode is on, but it's not.
You probably have a shorted spark module. send model # for more help. Hope this helps!
Feb 16, 2009 | Kenmore Kitchen Ranges
Ignitors won't stop clicking
there is dirt between the ignitor and the burner or the ignitor is to close to the burner
Feb 15, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
GE XL 44
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Jul 15, 2007 | KitchenAid KGST307 Gas Kitchen Range
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
537 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
