Question about Casio EXILIM ZOOM EX-Z70 Digital Camera
Camera will not advance to allow to take next pic
A few weeks ago I noticed that after I took a picture, the LCD screen would show black and not allow you to take the next picture. If I turn it off it will come back on and be ready to shoot(I can see the objects in front of me). I fooled around with some of the setting, but can't figure out what's wrong. I am not real good with digital cameras.
  • trosenvall May 12, 2009
    Camera often turns black after taking a picture. It will sometimes come back after turning the camera on and off, but it is getting worse. Sometimes there are lines in the photo, and when I tried taking a picture outside the other day it was mostly white. I have tried resetting the settings, but that didn't help.
  • rachel23 May 22, 2009
    I had the same problem with my camera for a while, the screen would turn black after taking one picture and any picture i tried to take after that would just be black. I tried messing with my camera a lot and after a while it stopped doing that and i was able to take pictures normally again. Now, however, the camera won't turn on at all anymore even after the battery has been recharged. When i put the battery in, the green light next to the screen does blink but the camera won't do anything after that. Does this indicate a problem with the battery or the camera itself?
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Posted on Sep 13, 2008
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
Taking black pictures
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
By the way, stop banging on it. That's a last resort fix for a lens error :-)
May 17, 2008 | Canon PowerShot A75 Digital Camera
Canon powershot a540 black/web screen display
jvsnype and ygjeff21, have you checked to see if the pistures also come up as blank or distorted (a sure sign of a CCD failure)? If the pictures are OK, then it might be that you accidentally hit the DISP button, or the camera has a loose LCD ribbon cable connector. The reason I would suspect either is that ygjeff mentioned that the LCD would spring to life when he played with the buttons on the back of the camera.
If and only if the camera still takes good pics, and the DISP button has been checked, then would next recommend reseating the LCD ribbon cable into its connector (ALSO ONLY IF THE CAMERA IS NO LONGER UNDER WARRANTY). The following link may be of some help. Wouldn't recommend going any farther than the first three pictures. You just want to jiggle or reseat the ribbon cable where the LCD connects to the circuit board, nothing else:
http://photography-on-the.net/forum/showthread.php?t=251630
Feb 06, 2008 | Canon PowerShot A450 Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Apr 22, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Stopped taking pictures . . .
When previous pictures display fine but does not take new one directs the problem to camera mode problem. Some component is at fault in the main board which controls menu functions and display is damaged. For the solution, the main board is repaired or replaced by technician. The repair cost may run between $100 to $200 in US.
Mar 21, 2007 | Nikon Coolpix 5600 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Viewing is fine, taking pictures is not
This sounds like what started happening with my camera a few weeks ago. I found that turning the LCD screen off during picture-taking allows me to take pictures. I then have to go into review mode to look at the pictures I took using the LCD screen. Definitely not a great fix. I'm trying to locate a firmware upgrade that may solve it.
Sep 01, 2006 | Sony Cyber-Shot DSC-W1 Digital Camera
Open Questions:
See all Casio EXILIM ZOOM EX-Z70 Digital Camera Questions
Casio EXILIM ZOOM EX-Z70 Digital Camera Logo
51 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
