Question about Intertherm P3RA-048K Air Conditioner
Air-conditioner our air conditioner feels like its blowing heat but its on air
  • imbucko1 Feb 04, 2009
    keeps stopping with E4 on the panel
  • 67 Answers
My aircondition in my house evrytime we turn on its covering eyes and has not blowing a heater can you give me the answer please.
Posted on Jan 07, 2009
Posted on Dec 31, 2008
Number one ...is outdoor fan running? yes- no if yes then proceed to next step. is compressor running yes-no if yes then low on freon call a pro, if no then look at big silver battery looking device known as a capacitor. is it swollen up and looks like a dead fish bloated by the side of the road? then its bad. it may also be weak. needs to be tested to within 10 percent of its rated value printed on the side of it. buy a meter and test it or take it to amotor shop and theyll test it. if all starts up and runs ok then have a smoke and watch it 30 minutes . the suction line should be cold to the touch like a glass of ice cold drink the little line should be slightly warm about 10 to 15 degrees warmewr than the outdoor air. if fan motor doent run on initial startup then the cap may be weak or bad test it. also gain access tom the motor and grasp shaft firmlyn anmd opull side to side perpendicular to the shaft. any cluck or play side to side and the bearings or bushings are bad and you need a new motor. good luck...
Posted on Oct 11, 2008
  • 4 Answers
If it is blowing then I presume the fan is working.
Can you hear compressor running?
If not possibly run capacitor bad for compressor or bad compressor or freon leaked out.
If there is any freon left and it is low,and the copressor is running, the evaporator coils will freeze up. Generally on wall/window units there is no service port to charge unit. I do not recommend saddle valve access ports since these allways seem to leak in time.Good Luck
Posted on Jul 24, 2008
Refrigerant is not being cooled at condensor coil.hot refrigerant is coming to evaporator coil inside.outside fan is not working.Bad fan capacitor (usually) or bad fan.
Posted on Jul 08, 2008
2 Suggested Answers
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
Electric heater blows cool air unless i turn the thremostat up at least 5 degrees higher then it goes to high and blows warm air
If it's "dual fuel" like heat pump with gas heat, the heat on the heat-pump side won't "feel" warm in the extreme temperatures we've seen in much of the country lately.....2nd stage gas will feel MUCH warmer. If purely electric, 1st stage heat may be off due to a manually resettable high limit switch/ bad heat contactor (giant relay), or a misapplied or defective thermostat. NOTE: if somebody recently painted OR wallpapered, AND it's a mercury-bulb T-stat, It HAS to be level and the connections must be tight!
Jan 28, 2014 | Ruud Central System Air Conditioner
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
The coil outside is 45 degrees but the air blowing in the house doesnt feel cool
Is this a heat pump? If so it sounds like a stuck reversing valve.
Sometimes cycling the thermostat between heat and cool will free it.
Jul 23, 2010 | Goodman CKL42AR42 Air Conditioner
No cold air blowing from vents
faulty indoor fan motor, check for blown fuses first in the indoor fan unit first before replacing motor. i live in s.a to i feel your pain.
Jan 29, 2009 | Heating & Cooling
Heating not working like it should
The fan for the A/C should blow harder than in heat. The fan should be on high for cool and low for heat. You can change the heat setting for medium but I would not recommend it because it may make heat coming out feel less.
Nov 21, 2008 | Heat Controller Thru-Wall/Window Air...
Intertherm P3RA-048K Air Conditioner Logo
130 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
