Car Audio & Video Logo
Posted on Jul 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireing diagram for a alpine cda-7892 - Alpine Car Audio & Video
Anonymous
Level 3:
  • Master 405 Answers
  • Posted on Jul 06, 2008
Anonymous
Master
Level 3:
Answers
405
Questions
Helped
261279
Points
1263
Good Day,
Red is ignition
Yellow is constant hot
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant if equipped
Orange is ilumm
Make sure you use the proper wiring harness for your vechile.
Hope this helps
How do i turn on an alpine cda 792
Press the Source button.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjehfyp5JfbAhWq3YMKHUVRCRcQFggpMAA&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F5%2F58a5b847-40d6-4050-b9f6-665dcac29113.pdf&usg=AOvVaw0bgzRI_YgcM9HHxL6fTHFp
Want to install an apline stereo into a freightliner columbia
Just follow the Aftermarket Wiring Diagram and you will be fine
1helpful
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Need wiring diagram for cda-7892
Hi and welcome to FixYa.
Below is the wiring diagram for an Alpine CDA-7892.
It was captured from the user's manual available here.
Good luck and thank you for asking FixYa.
1helpful
Is the CDA-7892 supposed to have a backlight when off?
Hello ckabee1,
The "illumination" lead on the CDA-7892 is ORANGE and terminated with a spade lug. It should be connected to the appropriate instrument panel light lead from the vehicle wiring harness. You can download a copy of the manual here with all of the wiring color codes. If you do not know the vehicle color code, you can probably find it at www.modifiedlife.com. Just click on "Car Stereo Wiring Diagrams" at the top and select your vehicle make, model and year.
Hope this helps.
Is the CDA-7892 compatible with the 2004 Buick Century?
yes - you will require a mounting kit, wiring harness, and antenna adapter for a proper install.
It is a single Din Sized industry standard aftermarket radio.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
2answers
Remote wire color?
the remote wire will be a solid blue this is always the color no matter what deck you have
1helpful
On my Alpine CDA 7892 i have the aux cables right for my iPod but i don't know how to swith it to the "aux" , just CD or Radio, How do you switch it to the "aux" imput in the back
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Alpine cda-7892 Head unit overheating
Certainly, the output IC might need to be replaced, also check to see if there is a factory amp somewhere in the car. Additionally, double-checking the wiring is a must. How long does it take for the unit to heat up?
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
