Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Ice from icemaker is salty tasting but water from dispenser is not
Maytag sidebyside w/dispener in the door. We have soft water and don't
know if there is a wter softener in the freezer or not.
    Problem Solver:
  • 4 Answers
Maybe a bad filter??....or too much salt in the softener
Posted on Jul 10, 2008
My Icemaker is filling up with frost around the ice dispenser spout. Have to pull the bin every 30 days dump the ice and clean it with hot water. The icemaker was replaced 2 months ago. What causes the...
You have a duct door problem. The most common is the seal on the door goes bad or the pivot on the dispener can break off. Both allow warm air inside thus your moisture. I hope this helps.
Aug 24, 2011 | KitchenAid KSCS25FKSS Side by Side...
Water to icemaker but not door
there should be two solenoid water valves in the back of the fridge one feeds the ice maker the other feeds water dispenser the one for the water could be bad or the switch in water dispenser
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
The ice and water dispenser of the door is locked on after hummin
Mark check for a door switch on the cabinet side oft the freezer door. It usually is near the hinge fold area of the door. Depressing the plunger should make the freezer compartment light go on and off. The switch also controls the icemaker auger power by shutting it off when the door is open. If the door switch has failed you will not get ice or water from the door dispenser. There are 2 plastic lock tabs of the side of the door switch to remove it. Use a knife blade or putty knife to unlock the tabs on the switch. If you need more help as to location of the switch respond here and I will pass a link for the diagram.
Jun 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice is made but dispenser does not spin so ice wont drop
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
May 24, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Terrible taste that came from water?...
Do you have a water softener? It's possible the softener was in soak when you used the water dispenser. That would explain the "salty" (hi sodium) water taste and thena retrun to normal later.
Also, if you get your water from a muncipal well, they may have been experiencing a problem at the time with higher than normal sodium content.
Apr 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker ice tasting funny
have yopu tried a filter on the unit yet sometimes that is the only way to rid of the taste.
Feb 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
438 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
