Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Water line keeps freezing
Our water dispener keeps freezing up. We were told by lat Maytag repairman to always keep the fridge full to avoid this poblem - but it keeps happening every few moths or so. To remedy we pull the deli drawr and place two wet, hot dishrags on the two hoses on either side of resevoir. But there has to be a better fix for this somewhere. Any help would be appreciated.
  • 197 Answers
What is the temp for the freezer set on
Posted on Jul 06, 2008
    Genius:
  • 1,142 Answers
The thermostat seems be be not working correctly
you need to replace it as its not doing its work properly.
get it replaced asap that will resolve the problem
  • 481 Answers
Turn your freezer control up almost all the way, and turn the refrigerator control down a little (tiny bit). this will slow the airflow  down in the back of the refrigerator near the water line.
  • Mike Durland
    Mike Durland Jul 06, 2008
    if the thermostat is bad then it would be a drastic temperature change not a gradual (every few months) problem.
Water tank freezes
I guess you've got it way too cold down there!
It's always a great idea to use an external Temperature indicator to
keep the Temp in limits.
Helps save power too and keep the electric bills down.
I set my fridge at 3-4 Deg
Freezer at 2 degrees below freezing
Digital Thermometer for Fridge or Freezer Keyrings Weather Forecasting...
Sep 18, 2015 | Refrigerators
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Freezer temp is -4 and refrig is 38. Not sure if these are correct settings but water in freig bladder keeps freezing and can't get water. Warmed bladder twice to get water to come out. If freezer temp...
Sorry if you don't like this solution, it does not make it work correctly. But my water works all the time now.
We too had the water dispensor stopping due to freezing of water in the storage tank. A blow dryer and about 10 minutes later we could get it working again.
We tried different fridge temp settings , and according to a thermometer placed inside the fridge in various locations we are getting the fridge temps we want, so it is not runing too cold.
I tried insulating the storage tank and the lines, this did not work.
I removed the tank and just connected the two lines, this still did not work.
I finally just pulled the lines out of the fridge completely and connected them underneath the fridge so water runs from the valve at back straight to door. The plastic panel on bottom was a great place to store the lines. I drilled a hole to reroute the door line to this area . Line runs behind lower plastic cover on front . The water does not get cold, but it never stops flowing, this was more important to us. I did consider rerouting both lines to the top shelf and putting the storage tank back in to get colder water, but no one minds the way it works so I probably will not do this. I would have run them up the back to avoid the inside lower area of the fridge. In the long run I will avoid this brand and avoid "twin-cooling" completely. All my neighbors and friends who bought this type all had to throw them away as they were too dofficult and expensive to keep running.
Jan 15, 2011 | Samsung RS2534 Side by Side Refrigerator
Water does not work. Possibly frozen line. i keep
I have a GE PSS25SGNA no ice no water freezer side is reading -2 refrigerator side 25 everything is freezing help
Jan 03, 2011 | GE PSS25SGNBS Side by Side Refrigerator
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
Power Cool button works on freezer , but not fridge
He Alisonki! I was having the same problem. On mine the water coil inside the refrigerator keeps freezing which keeps the water from circulating and my refridge won't stay cold. I was told by one repairman that it was a computer problem and you have to order parts from the Samsung Manufactuer which takes about 2 - 3 weeks to get. I am tossing mine and buying a more reliable brand. One repairman came yesterday and left without fixing anything or charging me. Larry
Aug 09, 2007 | Samsung RS2534 Side by Side Refrigerator
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
104 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
