Nokia 5800 XpressMusic Smartphone Logo
Anonymous Posted on Dec 27, 2010
Hi, I have a Nokia express music 5800 and the memory card is not detected. Pls give a step by step instruction process to detect the card.
Anonymous
Level 2:
New Friend:
  • Expert 109 Answers
  • Posted on Dec 27, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
109
Questions
0
Helped
24341
Points
317
First you check the memory card is correctly fixed or not and then you go to the gallery and check if it is not then go the service provider
Testimonial: "Thanks for the solution I will try it"
How to transfer music from laptop to nokia 5800
Connect the mobile using the connecting cord to the USB port of the PC. Now the phone memory will be detected. You can now scroll and select the music from your folder and copy to the memory card.
Also the memory card can be inserted directly into the slot of the laptop and the music files transferred.
5helpful
Unlock my nokia 5800 xp
To get the Unlock code for the Nokia 5800 Express Music you can reach the site Mobileunlocksolutions.com and buy it ,unlock it,specify the current Network and Country it locked now?Because there you can unlock code for some countries GSM Network not for all,You can enter the code correct using the instructions below:
Nokia 5800 Express Music Unlocking Instructions:
Warning : Do not enter any wrong unlock codes on your Nokia 5800 XpressMusic mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5800 XpressMusic mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5800 XpressMusic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5800 XpressMusic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5800 XpressMusic would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5800 XpressMusic mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
1helpful
Unlock code nokia 5800
How to transfer my contacts on my phone memory on Nokia 5800 express music to my sim card?
All you need to do is to open MENU>OPEN CONTACTS> SCROLL and see COPY CONTACTS.
Now select MOVE FROM PHONE MEMORY TO SIM and start copying. Now most of the SIM cards will have only provision for 250 contacts and so once loaded you must transfer the details to your new phone. and repeat the process.
Use the option COPY FROM PHONE TO SIM only if you want to retain the details on the phone.
1helpful
How to remove the country lock?
Which Network,in which Country It locked too?
Because all Network lock cannot be Unlocked...I have Unlocked My Nokia 5800 Express Music Using the UNLOCK CODE.So you can use the Unlock code to Unlock the Phone,You can get the Unlock code from here
Theunlockarena and Unlock it....You can follow instructions below and unlock it step by step..
Nokia 5800 XpressMusic Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 5800 XpressMusic mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5800 XpressMusic mobile phone, your phone may get hard locked and sometimes become unusable.
4helpful
How to open line nokia express music 5800
Which Country's Network Lock Do you need it open from ?
To open it from the Network Lock,get the Unlock code and instructions from
Mobile-unlocker and Unlock it.You can follow the instructions below and Unlock it step by step:
Nokia 5800 Express Music Phone Unlocking Instructions :
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5800 XpressMusic
3helpful
I want to download music using my usb
Hi,you can transfer music to nokia 5800 from your computer(pc or mac). There are different ways of transferring music.if you have a PC, you can use PC Suite to transfer music files.the nice software that comes with the phone. If you have a Mac, you can use Nokia Multimedia Transfer (free download) and sync it with your iTunes.
how to put songs on nokia 5800-nokia pc suite
To transfer music as data files, make the connection with a compatible USB data cable. You also need to have a compatible memory card inserted in the device. View your nokia 5800 on a computer as a mass memory device. follows these steps: firstly, connect nokia 5800 with computer via USB data cable. then select Mass storage as the connection mode. A compatible memory card must be inserted in the device. then view the device from the computer file manager as a mass memory device. now you can fansfer the music files. after transferring songs, you can close the connection by remove the USB device safely from your computer.
Hope it helped.
1helpful
I have nokia 5800 express music and how i can format my nokia 5800 phone memory
Its simple,
Solution :- Type *#7370# on your phone & then select Yes.
Your phone memory will format.
Thanks.
Happy to help you.
Music player can't detect files in memory card
may be its not compatible for your phone.or try to format your memory then put again some music files.If not,reset your phone or upgrade your firmware so as to work it normally...
2helpful
Media problem
General system error means it's software is corrupted, just reprogram it. It cannot detect by pc because it have no identity at, just reprogram it and it will work fine, maybe it's infected with the virus while you're synchronizing with your pc.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
