Samsung rear projection tv, have fault of ghosting red to the right hand side, this started out of the blue with no faults before
  • keithbstorey Jul 21, 2008
    ghosting red to right hand side
  • 8,617 Answers
Sounds like the convergence ICs need replacement. Whats the model number of your set? Please respond to this same post with your model number.
Posted on Jul 06, 2008
I have green outlines on the screen
YOU NEED TO REPLACE THE CONVERGENCE OUTPUT I.C.
Dec 26, 2009 | Samsung HCM4215W 42" Rear Projection...
Green out of alignment on samsung rear projection tv
Hi luke I am in the uk and not familiar with this set is it a three tubed crt television or an lcd projector type .. either way what you are descibing is convergence ( three primary colour guns all pointing at the same spot in a nutshell ) in the case of a crt projection tv three tubes one red one green one blue .. there should be a convergence pattern in the menu to re set the convergence via the remote check the manual . If it isn't adjustable you may have a scan coil fault or a tube ie : green with low emission check the green colour gun transistor and associated circuit for leaky caps resistors that have changed value or transistor leakage .. and don't forget the ever popular dry joints on the scan coil plugs .. hope this helps Vortash
May 29, 2009 | Samsung HCL4715W 47" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Samsung Projection TV -blue colored ghost / color off
try replacing the convergence ICs and also check the resistors that power them. This is a common fault with all projection TVs.
Mar 22, 2008 | Samsung PCN5425R 54" Rear Projection...
Convergence problem
check all resisters around conv ic's, also replace ic that connects to the burnt resister.
Feb 13, 2008 | Samsung HCL5515W 55" Rear Projection...
Tri coloured ghosting
maybe...it might need service mode aligning be a tech
Jan 02, 2008 | Televison & Video
Weird convergence
The convergence IC's are the culprit. Its a common fault still for as long as I can remeber projection tvs. Even the front projection types had convergence problems when the manufacturers switched from discret componets to Integrated circuit. Most sets have two IC's some have three. Its always better to change all the IC's at once, as the problem will occour on the others a time down the road, and more labor involved. A typical convergence repair is around 300 or so. Its not a consumer replaceable part unless you have the experience with soldering and know the issues related to the Hi Voltage and safty involved with the serviceing of these sets. Good Luck
Jun 15, 2006 | Toshiba 46H83 46" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
