Everytime I start a load, nF comes on, have to start cycle, or different cycle everytime, its only like a year old....been doing this, can't find booklet...what's it mean, nF, and how do you fix it!?Everytime I start a load, nF comes on, have to start cycle, or different cycle everytime, its only like a year old....been doing this, can't find booklet...what's it mean, nF, and how do you fix it!?
I have a samsung front end load washing machine that only runs a few minutes then kicks off with an error message of nf. Can you help me out ? ThanksI have a samsung front end load washing machine that only runs a few minutes then kicks off with an error message of nf. Can you help me out ? Thanks
You can't post conmments that contain an email address.
If water flow is OK from the supply, remove the top cover and check the pressure hose that runs from the tub to the pressure sensor. They have a tendency to come loose on these machines. That is what my problem was...Always unplug power before removing covers...
The "NF" code usually means that the washer has detected no incoming water flow.
Since you have water flowing into the machine, then the pressure switch system that detects the water level is faulty. The most common issue is a clog in the air tube that connects to the pressure switch. This can usually be cleared by blowing into the tube after disconnecting it from the pressure switch. (Unplug the washer before attempting this.)
After that, you need to check the resistance across the pressure switch and the wiring up to the control board. The control board could also have a fault. There is usually a tech sheet in the washer near the control board with the expected resistance values at these points.
Please add a comment with the washer model number if you'd like me to search for the parts list and diagrams. I hope this helps.
It means 'not filling'. So either nor or both of your water lines are turned off or just barely open, or the filter screens on your hose washers are clogged. Clean/clear them, or check water flow and you should be good to go.
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
