Question about Nikon D70s Digital Camera
No power Seems that some moisture has made its way into my body. Camera would not turn on for 8 hours with fully charged battery and suddenly worked. I took the battery out for the night and the next morning it would not turn back on. i have charged the battery and am confused at this mystery. PLEASE HELP!!!
  • 3 Answers
Look for an airtight container, find a silica gel or dehumidifier, a dry charcoal may also do the trick, you may also roast dry some corn kernels or rice and put in the airtight container and place your battery or camera inside to dehumidify it. You can use a plastic bag and just seal it. This will take moisture out of your unit and its battery.
Posted on Aug 08, 2008
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
HD camera.flip style
Did you do the Setup when you first started it? by holding the red button and following prompts? (to set up Language, date etc.) - if not try that. if yes, have you tried recharging it? Mine takes about 7 or 8 hours to fully charge (the red light will come on then when fully charged that light goes out) - it appears you have Ultra HD like me, so you should also be able to try some regular AA batteries in place of your rechargeable just to try that. If it works then, it is your rechargeable battery pack - either no good or needs charge. also when plugged into USB that red light should come on on front of the camera and if you look at the screen it should show a battery icon with a lightning bolt over it, shows the battery -how much charged. after 6 or so hours, press your red button and look at the screen - it now should be showing a battery icon that should by now be mostly Green and almost fully charged.
While charging the unit, Flipshare software comes up on your computer, "X" out of that software, so your camera will charge faster. My camera was doing similar things but I've had it a long time, and regular batteries worked, So I ordered a new battery pack and it has been fine since. Good Luck!!!
here is link to "what to do if battery not charging"
Jun 04, 2013 | Cameras
Canon DSLR will not turn on
Hi there,There are a few things we can try/check here!
1.Turn the camera OFF. Remove the battery and clean the contacts (shiney metal strips) on the battery.2. Remove the lens and clean the lens contacts.3. If you have a body cap, put it on the camera (no lens, just to keep dust out right now).4. Reinstall the fully charged battery and turn on the camera.
It should start up. If so, turn it back off and reinstall the lens.
Also, be sure to check all the doors/hinges on the body. These are found on the battery and the memory card. They have electrical contacts on them that need be to be fully closed.
If possible, try a different battery (a friends, or take it to your friendly neighbourhood camera shop).
Hope it turns back on!
May 07, 2012 | Canon EOS Digital Rebel XTI Digital Camera
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
Howcome my camera wont on? i was just charging it and uploading pictures and all of a sudden i tried turning it on it won't on.
Your battery can't able to store charging. please use a new battery with fully charged. I think these battery complete his service hours.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Kodak EasyShare M1033 - black Digital...
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
try removing the battery for 24 hours and allow the battery to charge for that long as well unless you charge the battery in the camera with a docking station then just leave it out also take a good look at the lcd when you try and turn it on see if the image is really dark but their is still a image. one this that I have noticed while working on casio is that a lens error can cause the lcd to be very dark and you can barley see a image but it is there so it causes you to thing the camera is dead. If you do see a image then the problem lies inside and needs to be serviced but if you don't then it lies in the power source. ie battery or power circuit of the camera. after the battery shows charged have it tested with a ohm meter it can help determine if it is a good battery. you can have it checked sometimes at radio shack or a place called batteries plus if you do not have one. I hope this helps out I know it can be frustrating but it happens. good luck.
Feb 03, 2008 | Casio EXILIM EX-Z1000 Digital Camera
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Nikon D70s Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
