RCA D52W19 The power light comes on three times and it makes a noise but the tv does not come on I have the same problem except the TV is RCA60W20
  • TonyPA Jul 13, 2008
    I ordered the Flyback Transformer (RCAFlyback Transformer 259296) based on prior discussions you had with other clients. I see there is a red wire and black wire going to this unit and want instructions on proper removal and reconnection of these wires to the new transformer. If you could, please provide direction for properinstallation of the transformer. Thanks.
    The pins and soldering I understand. My concern is how the (2) wires are connected in the top of the unit. They do not pull out easily and I do not want to force anything. Any suggestions?
    I also noticed your prior response questioning if it is the Flyback transformer. I obtained this info. from reader other responses on your site. If there is some other troubleshooting I should try that may be easier to rule out than replacing the transformer, please let me know. Thanks.
  • 19,396 Answers
3 times means a convergence problem on many tv set, I will check exact codes on your RCA.
Posted on Jul 13, 2008
  • 4 more comments
  • Ginko
    Ginko Jul 13, 2008
    Hmm.. How did you know it was the Flyback transformer? Did you test it? Here are instructions for testing it.
    I will see if I can find wiring diagrams or replacing instructions for your model
  • Ginko
    Ginko Jul 13, 2008
    Moreover flyback transformer is a high-voltage unit that connects directly onto the back of
    your TV tube and controls the electron beam that draw the picture, its replacement and installation requires precision soldering and working on parts that can give a strong electric discharge, even after TV had been disconnected from power.This kind of job should be done only by an expert repairman.
  • Ginko
    Ginko Jul 13, 2008
    To replace the flyback yo should remove solder from all pins and then press the clips holding the transformer.
    When replacing it be careful with the tube, the smallest crack in the tube is sufficient to cause a strong implosion.
    Leave TV disconnected from power for over one hour before working on it.
  • Ginko
    Ginko Jul 13, 2008
    After replacing flyback transformer you will need to do again alignment procedure, here is how.
  • Ginko
    Ginko Jul 13, 2008
    My last suggestion is to buy service manual, that will contain all diagrams to replace the flyback transformer. I think its consultation will be helpful, if not mandatory in your case.
    Regards
  • Ginko
    Ginko Jul 13, 2008
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Rca d52w19 fix fuse name
thats not a fuse issue, its a defective flyback. You can get a replacement flyback at the following link with free installation instructions so you can easially install it yourself. You need flyback number 259296 here is the link.
http://servicemanuals.vstore.ca/
Aug 22, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19
thtas the error code which means the flyback needs replacement. Its a inexspensive easy repair you can get a new replacement flyback at the following link for less than 50 dollars which includes shipping and free tech support to help you install it. You need Flyback 259296. Here's the link.
Jun 26, 2008 | RCA D52W19 52" Rear Projection Television
Rca tv will not power on
Check the horizontal output transistor. This may be shorted.
Mar 12, 2008 | RCA D52W19 52" Rear Projection Television
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
Power Surge?
Sound? audio from station.. or noise this set is going into shutdown. the processor is seeing a problem with its safety cuircits and shutdown the set it will try to restart the set 3 times and then lock it down. it can be many things. the processor has an error log.. technician can get in and read codes.
Nov 16, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
