Question about RCA OPAL M4001 MP3 Player
RCA Opal won't hold charge
My opal is not even a year old and won't hold a charge. Now my computer will not even recognize it's hooked up. Help.
  • 6 more comments
  • dancerkaren Jul 07, 2008
    how do i do that
  • andreasmith Jul 07, 2008
    yes my thing that is in the back the charging thing is broke how do i fix it
  • Ozzblue Jul 17, 2008
    It won't turn on at all, is there away I could somehow reset it?
  • Anonymous Jul 24, 2008
    My RCA Opal MP3 player will not turn on, so I pressed the restart button with the end of a paper clip. It turned on, but it took like 15 minutes and then died after about 30 minutes. I also checked to make sure the hold was not on and it wasn't. I recharged it, but then it wouldn't turn on at all, not even with the restart button. I charged it again and there was nothing left in the battery, and I didn't use in in between the 2 times I charged it (which was only a few minutes after I charged it the first time) I think the battery is not holding it's charge. What should I do about this?
  • Anonymous Jul 26, 2008
    My ipod sat for a month or so ad now I cant charge it it is so dead, it wont even turn on.
  • Xanite Oct 08, 2008
    mine wont even do anything when it is hooked up to my computer, it wont turn on, wont charge, cant get firmware because the computer wont acknoledge that its hooked up. it worked for a week, the warrenty is gone after a year, does anyone know what to do? or is it dead, gone, broke beyond repair
  • RMSsydney Mar 13, 2009
    ok i put a burnt cd in my rca and it quite workin
  • marinity Mar 15, 2009
    I have the same sort of problem... I think. Like, okay, I turned it on this morning and it worked perfectly fine.. I turned it off for church. When I come back out of church and go to turn it on again, it gets to the 'Please Wait' screen, and it froze [I know it froze cause usually when it's loading the little period dots like, go to three then fade and start over.. well it was stuck on 2 for like 5 minutes],.. so I turned it off and tried again, then it was stuck on the Initializing screen for like ever.
    So I decided when I got home to just try to plug it in to charge it... but now, it won't even read it. Like, it's as if it's not plugged in. The screen wont come up to say it's connected, my computer doesn't react, and it won't turn on at ALL now. ><;;;
  • 8,596 Answers
Make sure hold/lock is not engaged
Restart
Get the firmware upgrade from RCA website
If it is less than a year old, call RCA if these methods fail and get a replacement - hope you still have your receipt.
Posted on Jul 06, 2008
  • Corey Knoettgen
    Corey Knoettgen Jul 07, 2008
    All of your answers are here:
    http://www.rcaaudiovideo.com/categories....
Its a good device but the same for me don't worry its not your fault RCA mp3 brake by itself
Posted on Jul 11, 2010
My rca wont charge....I dont know why..I left it there on all night but it wont go to the charging menu.usually when I connect it to the computer it goes to charging ipod but it doesnt anymore it turns on and plays the music...What should I do?
Posted on Sep 10, 2008
Rca opal 4gb M4304-A has completely stopped functioning
Wow, I didn't realize so many people were having the same problem I was having. First try re-installing the firmware for it. Since your computer won't recognize it you will need to download the software, then you will have 2 boxes pop up. One is the install instructions and the other is the actual program install. You will have to hold down the play button on your player while you plug it into the computer. DO NOT RELEASE THE BUTTON UNTIL THE PROGRAM SAYS "INITIALIZING".
It should work fine once you do this. I spent 3 hours going through RCA's website before I came across this step.
Nov 22, 2009 | RCA M4304 Digital Media Player
My M4002A RCA MP3 Player won't turn on. How can I fix it?
I got a sewing needle and put it in the reset hole on the back of the mp3
Jun 23, 2009 | RCA opal MP3 Player
My RCA opal m4002a doesnt hold a charge
Try updating firmare and software so that your computer will recognize it and maybe charge battery
May 03, 2009 | RCA OPAL M4001 MP3 Player
Won't do... anything...
The hold switch is on
Fatal error on RCA Opal:
What do I do if I experience a Fatal Error? How Do I reset my Opal?
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device.
Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
RCA Opal - Stuck on "Initializing"
Go to this website to reload the firmware:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1415&p_created=1202430585&p_sid=CwOaz8ej&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTIsMTImcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1pbml0aWFsaXppbmc*&p_li=&p_topview=1
Note: websites are subject to change - if you go to http://www.rcaaudiovideo.com and go to the page for the RCA Opal m series, you can also find the firmware reload on that page.
-Tha Mp3 Doctor
Sep 21, 2008 | RCA OPAL M4001 MP3 Player
Rca opal
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Feb 19, 2008 | RCA OPAL M4001 MP3 Player
Rca opal
Feb 17, 2008 | RCA OPAL M4001 MP3 Player
RCA M4018 8GB MP3 Player
Mine didn't recognize either, so what I did is go into the device manager, find the opal in the listings, double-click, disabled the device, re-enabled it, at which time it shows that there's a firmware error. I then re-installed the driver from the cd, unplugged the opal, plugged it back in, and for whatever reason, the computer then recognized the opal as a mass storage device, instead of a portable music player. The computer now sees it everytime, and all I have to do is drag and drop any files I want into the opal. Works like a charm. Hopefully RCA will provide an updated firmware program in the near future, but this might work for you for now. Good luck!
Feb 10, 2008 | RCA OPAL M4001 MP3 Player
Blue opal 2 GB M4002 not working
I have the same **** problem! Except I never dropped it or anything! I just hooked it up and it wont frikken recognize it. WILL SOMEONE PLEASE HELP! DDD: email me at Keeah5@hotmail.com ;_; This is soo agrivating.
Jan 23, 2008 | RCA OPAL M4001 MP3 Player
WWON'T POWER ON
For one, you don't need the CD to put music on the Opal. It's a plug and play device. Go to My Computer on your desktop and you will see under Audio Devices "OPAL". Click on that and you'll see a folder called "Media" and that's where you put your music.
For not turning on, click Pause/Play twice
For charging, You need to plug in the USB cord into the computer to charge it. Wait 3 hours. The Opal doesn't have a real long battery life, i'd say around 10-15 hours. So you'll be needing to charge it quite a bit.
Dec 23, 2007 | RCA OPAL M4001 MP3 Player
RCA Opal troubleshooting
Make sure the Hold Button - it's on the side of the Opal - is off.  When the hold button is on, it makes the Opal think the Flash disk is full, and you get all kinds of wacky reactions.
Hope this helps...
Dec 01, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
920 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
