Question about Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
Where would I find the auto adjust and manual adjust on the duo therm air conditioner.? Is it on the thermostat? Thanks
Richard
  • Anonymous Jul 25, 2008
    My Dometic will only cool to around 78 degrees before the compressor starts cycling on and off. is there a way to adjust the thermostat so I can cool it down to 65 degrees?
My duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
  • Nikea Junod Sep 30, 2013
    we are having the same issue although ours is doing it day and night. As well as now tripping the breaker randomly. Have you figured out what is causeing this?
My duotherm keeps freezing up what should I do?
Posted on Jul 31, 2008
I have a Dometik Duo Therm Brisk Air rooftop trips AC
circuit breaker when the weather turned hot. When circuit breaker is reset,
the unit will run for 5-10 minutes, cooling nicely, and then trip the AC
circuit breaker again.
Once the outside temperature went down, that evening, I tried it again.
The AC worked fine all night and the next morning, and then same thing cut off when it got hot.
Posted on Jun 22, 2010
Ok i just got this 5th wheel and my ac was working and now it just blows hot hair its 104 and i need ac do i need to put free on in it?? Need help plz
Posted on Jun 30, 2013
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
I have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Duro Therm air conditioner
Most likley this is caused by a pressure switch dropping out then making again after the pressure drops off. Try cleaning your coil on the outside on the roof as most likley it is a high pressure switch causing this problem.
Jun 30, 2008 | Dometic Rooftop RV Air Conditioner
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
2,840 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
