Question about RCA D52W19 52" Rear Projection Television
RCA DS1W20 Chassis ITC222
I have a problem where the TV will not turn on. sometimes it does and sometimes it doesn't. In pulling of the front cover, I see (3) individual boards with tubes. I think there may be a problem with one of the tube/board assemblies. if you are in agreement, is this something I can order and fix? Let me know what you suggest. Thanks!
  • RCA Master
  • 8,617 Answers
Go to the following link and leave a email with your model and symptoms. They are RCA experts and they will return your email promptly and they also have any part you could ever need for that model RCA. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 06, 2008
52" RCA Scenum froze and would not turn off. I unplugged it and then plugged it back in. All the lights are on in the front of the tv but it will not turn on.
The small signal board is the most likliest cause of that issue which is a very famous symptom for the ITC222 and ITC222A chassis RCA models. You can usually get the small signal board from www.tvrepairworld.com several versions were used so they can assist with identifying which version ssb your model requires.
Apr 03, 2013 | RCA D52W19 52" Rear Projection Television
How do you pull out the capacitors CP150,CP114, and CP120 in a RCA tv. Model:D52W14 and the CHassis # is ITC222
they need to be unsoldered and the new ones soldered back in. Be sure to observe correct polarity when reinstalling not the Negative side of the cap matches the shaded portion of the board for correct polarity
Apr 07, 2012 | RCA Televison & Video
I have an RCA DLP ,R56WH76, it wont' turn on period.
follow the power cord to where it plugs into the small AC filter board on the right side looking in the rear. Check the fuses on that board there is one but some versions of the ITC222 chassis has two fuses on that board.
Nov 23, 2011 | RCA R56WH76 Projection Television
While watching tv, there was a faint "pop" and the tv went dead. it will not turn on by front buttons or remote.
Does the power indicating flash three times then go out when power is pressed? If so you may need a deflection board which is famous for problems with the ITC222 chassis.
May 02, 2011 | RCA HD52W59 HDTV Projection Television
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" tv
It sounds like youre decsribing the ITC222 chassis HDTV rear projection. Look on the rear tag to see if its a ITC222 chassis and let me know and I can assist you with it.
May 18, 2009 | Televison & Video
MY RCA MODEL NUMBER D52W19 WONT TURN ON!
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 17, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
