Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
1800FP monitor ICE chip
Thanks for the advice. My father is fairly savvy in electronics and he basically said the same thing about the capacitors. He also noted that measuring capacitors with an Ohm meter can be deceiving based on how they are wired into the circuit, e.g., series or parallel. I think I am just going to buy that ICE chip for ~ 5$ on ebay and solder it in and see if it fixes the problem. They claim that the ICE chip is the cause of 9/10 of the power supply problems, does this sound believable? Also, I was wondering how specific each ICE chip is for each power supply. Could I just go pick up any old one, from say radio shack?
Hopefully the old thread was forwarded to you
Thanks again
You NEED the EXACT ICE CHIP, not just any old chip. They make millions of IC'S, you can get a reman power supply on ebay for cheap from ressurectek, tell him jimmyvisthekey sent you. Later.
Posted on Jul 20, 2008
LED light is and screen is black
Check the switch mode power supply IC for shorts. This is very common problem for this model, you can get the repair kit for it on EBAY.
Replacement power supply module: http://www.lcdrepair.us/1800fp-power.html
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 29, 2011 | Dell 1800FP Monitor
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor is dead
I have made a solution for this for you which can be found on my website here:
http://www.dorchestercomputerrepairs.com/1800.html
Hop this gets you going again.
Sparkyuiop
Sep 01, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My dell ultrasharp 1800fp monitor keeps flashing on and off, its not a power problem as the power button stays on and when i disconnect the the monitor cable from my pc the no signal message stays on the...
Inside there is a IC chip on the power pack that goes bad, replacement is called for also look for bad capacitors when you are inside looking around, those need to be replaced as well
hope this clears things up. dells third party who built these units did a rotten job on this model. that chip always fails.
Aug 19, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Ice 2as01 is broken again
Resolder diodes D903 and D906 in the secondary of power supply. The diodes are the two mounted to a heatsink. These are the reason the 2AS01 goes out in the first place. The solder joints on these two diodes breaks loose. If you don't solder them, the 2AS01 will go out again.
Aug 04, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
1800FP ICE chip
The ICE chip is not so easy to get. Your best bet is to use the ebay source. cheap quick and easy. It would need to be an electronics wholesaler, a trade type distributor to get that part. Most would not stock it.
Jul 06, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
1800FP power supply
The best way to get this to Robotek is to go to the home page and select find experts. Locate his name and use the ASK ME option. I will forward the link for this string to him as well.
Dan
Jul 02, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP - no power
Hi pcpiuk
If you have a multimeter, and want to get into the electronics of it all, you could rip the covers off and sus it out. Here is a pictorial guide on whats in it. You need to check the power supply for operation. If it appears to be producing voltage(they usually do or they dont) then it will be ok. The common cause of failure in the power supply is the regulator IC ICE2AS01 an 8-pin DIP chip, and resolder the entire PC. Around power devices I use solder with 2% silver content as it creates much tougher solder joint. If the power supply checks ok, then the inverter is the next spot to check. Just replace it if it appears to be the problem. You can get spares to rebuild the power supply and even new boards from ebay or Dell direct.
If you have any trouble getting parts, comment back to me here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 26, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP has slight yellow cast
Your Display cable (inside your monitor) needs to be replaced. (Or reseated)
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
Mar 04, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP
What's wrong with your monitor?
Feb 10, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
126 people viewed this question
Alun Cox
