Question about GE GSS25SGMBS Side by Side Refrigerator
Replacing the ice maker mechanism on a GE side by side
I bought the parts and rebuilt the ice maker but am having a hard time figuring how to reinstall it in the back
    Genius:
  • 1,142 Answers
  1. Unplug the refrigerator.
  2. Remove the icemaker's front cover by unscrewing or prying it off as needed
  3. Remove the ice bin, shelves, and vertical partition.
  4. Remove remaining screws, disconnect the icemaker wires from the harness connector or socket, and remove the unit from the freezer.
  5. Remove the back access panel and any fasteners that hold the inlet valve to the refrigerator.
Posted on Aug 07, 2008
Gss20I eph ice maker ?? If I turn the switch of
I am almost sure the model ice maker for your refrigerator is Click Here=> WR30X10093 and the model number for your refrigerator is GSS20IEPHWW or SS for Stainless. It sounds as if a bad connection on the ice fill arm. The truth is they are electronic and made in China along with most of the parts on your GE. I replaced mine that was the mechanical type with this same model number WR30X10093 and the mechanical lasted 15 years. If you manually can make it work one time and fills properly but after one cycle yet turns itself off my focus is on the ice maker. If you want to check OHM's to the dual water control valves they should both be about the same. Applying 120 volts to each side of the coils being water dispenser side and ice maker side will or should open them. But you just said that moving the arm that it will fill one time so I am back to the ice maker again. If water control valve for ice maker side did not work you would not be able to do that. Sea Breeze
May 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker dispencer motor won't spin. You can hear a click, and the ice dispenser light dims. The water dispenser works fine.
Best solution is to replace the ice maker. The ice makers are a cheap item and very hard to work on. It is easier to replace the ice maker rather than trying to take it a part and replaced the motor or gears. If you do want to take on the project you have to remove the ice maker and check the gears for a worn spot and the motor to see if it is still running. Parts can be purchased at a local appliance dealer. In tulsa we have Greers appliuances.
Nov 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side refrigerator
Mike, Most times when this happens it's the water control valve for the ice maker side that becomes defective. If using an OHM meter you unplugged the 2 coils and read the OHM's they should be very close to equal. The part number for the water control valve is WR57X10032 and the part number for the ice maker is WR30X10093 Unfortunately the ice maker is electronic and there are no replaceable parts. You can test the ice maker by filling with tap water allow to freeze and if it dumps then the ice maker is good and the water control valve is bad, Thanks, Please Rate Me, Sea Breeze
Aug 29, 2009 | GE GSS20IEM Side by Side Refrigerator
Ice maker stoped working
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE now charging $75+ for answers
well i dont know if you still need help or you already solve it. when i repl repl the ice maker it works on all GE'S you probalbly bought part #wr30x10061 right that is all you need some older model have diferent ice maker that were mechanical this is an electrocnic ice maker is ok if you just repl it just use the extension if you need to coonect the wire harness
Jul 09, 2008 | GE GSS20IEP Side by Side Refrigerator
Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
Jul 20, 2007 | Hotpoint HSS25GFP Side by Side...
GE GSS25SGMBS Side by Side Refrigerator Logo
405 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
