Home | Sceptre | X9G Komodo IV (Black) 19 in. Flat Panel LCD... | Same Flashing Problem
Sceptre X9G Komodo IV  19 in. Flat Panel LCD Monitor
Problem for Sceptre X9G Komodo IV (Black) 19 in. Flat Panel LCD...
By evilrotary on Jul 06, 2008
My Sceptre 17in lcd is doing the same 1 second display and then shutting off, has anyone figured out that problem yet?
Same Problem
Nov 14, 2008
-   X9g Komodo II one for a second then black... any advice?
-   Guest
Aug 02, 2008
-   screen goes black, I hit on/off switch wait 20 seconds turn it back on and move the mouse and the screen comes back on for undetermined amount of time-   asktodd
Jul 13, 2008
-   the screen stopped displaying. If I press the button OFF and ON again, the monitor will display information for about 1 second and after that the screen is blanked/blacked out even the power is still ON (green). -   prace
Solution #1
posted on Oct 15, 2009
Not Rated)
Zeevert
Rank: Master
Rating: 81%, 4 votes
My Sceptre Komodo 19 would turn on for less than a second than turn off. Eventually, I could get it to stay up. But after a month, I couldn't get it to stay on anymore.
I found the solution on this website. There are some bad capacitors... 4 of them for about $2 worth. I replaced all four and the monitor works fine again. They are soldered in. They are polarized; they need to be installed the right way. The white stripe goes towards the “wall”.
2 are 470uf 25v and 2 are 1200uf 10v.
I ordered mine for about $10 with shipping from Mouser.com
661-EKZE250ETD471MJ1 and 647-UHE1A122MPD
Was this helpful?
Yes
No
Popular Solutions for Sceptre X9G Komodo IV 19 in.
Questions and Unsolved Problems for Sceptre X9G Komodo IV 19 in.
Do you recommend Sceptre X9G Komodo IV (Black) 19 in. Flat Panel LCD Monitor?
Answer
Answer
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any... (More)
Answer
Tried another LCD monitor on my system , it works fine. Can anyone help?
Answer
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts... (More)
Answer
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sceptre X9G Komodo IV 19 in....:
Top Monitor Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
