Put dvd into player andi twont come back out - Televison & Video
    President:
  • 173 Answers
Hello reddog_429,
With the power cord unplugged, open the case by removing the screws on the side and a few in the back and your should be able to get the top of the case to come off. 2. Now you will be able to see disk inside the carriage a bit better. 3 Try and manually push the dvd tray out (You will feel a slight resistance, but the tray should eventually come out enough so you can remove the disc). 4. Now that you have the movie out, you should take a can of compressed air and blow out the inside of the player, you should also take some cu tips and lightly dip them in alcohol so you can clean the optical lens and all around inside the carriage.5 Repeat blowing and cleaning with cu tips a few times 6. Take a small flashlight and look inside to make sure there is not more dirt, dust, etc 7. Check to make sure all the gears and drive are working normally by gently pushing and pulling the tray in and out while looking with the flashlight. 8. Replace the cover and plug your player back in and without putting a disc in it open and close the tray by pushing the eject button and if everything is working fine at this point, you should be good to go. If it is still giving you problems then the drive motor has probably failed and you will need to take it to a repair shop. Hope this helps and let me know if you need further assistance.
Posted on Jul 06, 2008
My samsung ht c350 wont eject, it says lock when i try to eject it
Found out how to solve this problem, as it has put a child lock on the device, try holding the Stop button on the remote for five seconds. This resets the device, then turn it back on and it will go through inital setup and then try oepning the tray.
Andy
Jan 14, 2011 | Samsung DVD-C350 DVD Player
My radio/navi keeps saying "it is not possible to operate this function while in memory navi mode"...how do i get out of that mode? thank you...andy
Sorry Andy, that feature is built in at the factory so you cannot watch a DVD while driving.. maybe a radio shop will know how to bypass it.
Nov 14, 2009 | Pioneer AVIC-D3 Car DVD Player
Motor replacement on a portibal dvd player
U can us any replacement motor as long as there are no gears attached to the motor.Gears change speed and ratio of player
Jul 21, 2008 | Philips Magnavox DVD/VCR Dual Player
Vcr only plays in black and white
Hi Ryana,
Check if the recorder is set to output in 'S-Video' or 'SuperVideo' mode, if your TV doesn't understand S-Video you'll get a grainy B&W picture. The VCR should be set to output in PAL for the UK and most of Europe.
Hope this helps
Andy
Jun 26, 2008 | Philips DVP620VR DVD Player/VCR
How do you connect the outside antennae to both the dvd player and digital converter box and the television
if its a dvd recorder first connect arial to recorder,then connect arial out to arial in on next device,and so on,it will say uhf in and out,on back the tv should be the last one connected,and you can also link them using scart leads and then use av on remote control, hope this helps andy
Jun 22, 2008 | Televison & Video
Power on problem
http://www.drx9000repair.netfirms.com/#Cyberhome%20CH%20300
May 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Kenwood KVT-729 dvd
I think you are in dual zone mode. Switch back to single zone mode to see if it help. Goodluck.
Feb 17, 2008 | Kenwood KVT-617DVD Car DVD Player
Sony DVD player
You have one of a few problems, One the spindle motor or the spindle motor circuit is bad. The laser assy is defective, as all cd/DVD players must focus on the disc before it will spin, or the platter or "hat" is off or out of alighnment. Most of these problems will not be worth repairing, as the cost of repairs will exceed the cost to replace. Good Luck
Oct 07, 2006 | Sony DVP-NS315 DVD Player
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
