Question about Kenmore 62722 Electric Dryer
Kenmore dryer swap pwr cord from a 4 to a 3 prong
  • merwin63 Jul 07, 2008
    you missed the ground strap needed moved back to center (I bellieve white), neutral is in center bu I se no indication for whichside is on red and which goes on black!
  • 246 Answers
Remove the cover plate just above where the cord goes in (1/4" screw) Loosen all 4 screws (3 brass ones and a green one) and see if the connectors will come off. (this is for a "fork" type connector) if the connectors won't come off, you have a "loop type connector in which case you will need to remove all the screws completely. BE CAREFUL! If you drop one inside the machine, you will have to dis-assemble it. Now, re-install/ tighten down the green screw. (If the green screw wasn't used, the unit wasn't installed correctly at the time of install). Loosen the screws on the clamp where the power cord comes into the washer. (again, they may be missing do to improper install). Now, install you three prong cord in reverse. (The cords are flat so you can't mix the wires up on most models of cords) Make sure to put the clamp (strain relife) on that was supplied with your new cord.
Posted on Jul 06, 2008
  • Toby Norton
    Toby Norton Jul 07, 2008
    My appologies. I read it as going from 4 to 3 instead of 3 to 4. red and black go on the 2 outside screws of the 3 terminal screw block. The white goes in the middle and the green ground strap goes to the green screw.
Changing 4 prong plug to 3 prong plug on a Kenmore ultra fabric care electric dryer, where is the metal strap?
The metal strap connects the neutral to the housing ground connection when using a 3-prong cord. It may have been removed when the 4-prong cord was installed.
Feb 17, 2017 | Kenmore Dryers
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
The cord need to be changed from a 4 prong cord, 4 wire to a 3 prong cord, 3 wire 220V. which of the connections do i connect to?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 15, 2010 | Kenmore Dryers
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Swapping dryers
just remember a 3 prong cord the middle wire goes to the middle on the terminal block,the other 2 does not matter there both 120 volt,same if you have a 4 prong,the white wire goes on the middle on the terminal block,the red and black go on each side and the extra green gets mounted to the cabinet,,let me know how you do-mike
Mar 23, 2009 | Kenmore Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
I have a 4 prong power cord coming out of my Kenmore dryer and I have a 3 prong power outlet in my wall. Can I replace the 4 prong cord with a 3 prong cord, and if so, how?
Purchase a 3 prong cord at a home improvement center. and replace your 4 prong cord. all you need is a screwdriver.
May 02, 2008 | Dryers
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 62722 Electric Dryer Logo
188 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
