Question about Foxconn 865G7MF-SH Motherboard
Pls. help me with my motherboard
I got two master hard drve in my cmos settings
my problem is i cnt change the other sata to slave
they both master my main HD is seagate 80gb ( Master )
the other is seagate 320gb (master wich i want to change to a slave)
but dnt know how to change i2. Pls.. help me
or send me some feedback at my mail its DyuN_whamMe@yahoo.com
Thank You So Much and godbless to you and to your family T_T
- DyuN
  • 1 more comment
  • iCe_sPeRm Jul 06, 2008
    i got two master hard drive in my cmos settings
    but i dnt know how to change it. Pls.. help me
    - DyuN
    sir map9966
    my problem about my SATA HD is the wndows detected it and
    used it for a couples of times but after 2 days i got a problem
    with my 320GB. when i go to my computer the 320gb seems not detected then i go to devce manager and scan the HD for hardware changes the system scan it and the 320gb appears
    in my computer but after an hour ago usng my pc it dissapear
    again. pls. help me again sir to solve my problem.. Many Tnx for your reply.
  • iCe_sPeRm Jul 07, 2008
    OK sir mike im gonna try your helpful tips. i hope it will work
    Many Tnx To You And to this site...
    Many Many Tnx.... Gobless,,,,, ^_^
    President:
  • 2,351 Answers
Hi iCe_sPeRm, all SATA drives are seen as all masters. While in the bios you'll want to connect the SATA with windows on it to the SATA 1 port on the board. So back in the bios you should see the 80GB drive listed first. The 320GB drive should be on the 2nd SATA port & listed second in the bios under the 80BG drive.
The most important thing to do in the bios is make sure you're 80BG drive is the only drive listed in the boot order.
Once windows has loaded you may need to change drive letters using MS windows diskmgmt.msc. To load disk manager in windows click the start button, click run & type in the run window diskmgmt.msc & click ok. You can change the order that windows see's the drives. You can also rename the drives. EX: Rename C:\ as Master_Drv or Master_80. Than rename the 320GB drive as Slave_320 ECT. This way you'll know which is what.
Foxconn's web site for the 865G7MF-SH MB.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000204
Good Luck!
Mike
Posted on Jul 06, 2008
  • Mike Peluso
    Mike Peluso Jul 06, 2008
    Double check the 320GB SATA drive's data cable & power cable at the mother board & at the drive. Chances are the one or both have a loose connection.
    It only takes a slight bump for either cable to come loose.
    When you look at the cables they will look like their connected but give them a push! Vibration within the PC can cause either cable to come loose, just enough for the drive not to be seen. There is one other thing you can do. Take some house hold alcohol & place a few drops on a cotton swap or two. Clean the contacts of the SATA data cable (Both ends). This will remove any dust & help make better connection. Each time you loose the 320GB drive in windows. Shut down the PC & unplug the power cord to the PC. Check the cables again (Give them a push. Leave the case open & plug the power cable back in. Start the system & see if window see's the drive again. If windows see's the drive replace the data cable with a new cable.
    http://www.csncables.com/asp/keyword.asp...
    If you feel there is an issue with the 320GB drive you can go to the drives manufactures web site. Download the tools/utilities & setup software for you're drive. You should be able to create a bootable floppy disk or bootable software for a CD. Disconnect all drives except the 320GB SATA (The bootable software runs in a dos mode. You do not need windows). Move the 320GB drive to SATA port 1. Check the drive with the manufactures software.
    This will give you piece of mind that the drive is in good shape or not.
    Good Luck iCe_sPeRm!
    If you have more questions, continue to post them here.
    Thank You for allowing me to help you.
    Mike
I have 2 hard drives i want to make one master and 1 slave model HDSJ oth 7200 rpm
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
if you need more help with this post a reply
Hope this helps
Aug 18, 2011 | Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM...
How to set hd fujitsu MHZ2250BJ as slave ?
hope this helps
Aug 14, 2011 | Fujitsu MHZ2250BJ - 250 GB, 2.5", 7200 RPM...
Desktop Acer M1641: 1 IDE optical drive+ 1 SATA HDD. When SATA disabled,both drives appear in Bios n boot sequence. When SATA enbled, only optical drive in Bios. When both are present (as said before)...
Hope this helps
May 18, 2011 | Computers & Internet
Have a FIC K8-800T Motherboard. Works fine with 1 SATA drive. Does not recognize second SATA Drive if drive is very large
Hope this helps
Apr 20, 2011 | FIC K8-800T Motherboard
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Weird problem. CPU recognizes the sata, windows will not boot, recycles to start-up over and over. Tried with xp disc to repair, came back as "no hard drive listed. If I changer driver from master to slave...
It is possible that Bios/Cmos battery is not maintaining its charge. You might want to pull the cmos battery & check its voltage with a volt meter. It should retain 3volt DC. If it reads lower than 3v replace the battery. Once replaced you will need to reset all bios settings. If the battery checks out ok than continue.
The soulation to your problem lies within the Bios not your hard disk drive. Set the jumper you moved to slave back to master. Re-connect the SATA data & power connector to the motherboard. Boot up your PC & start pressing the Delete key on your keyboard every two seconds untill the Bios menu opends. (See page 2-14 section 2.3) in your manual.
You can not use your mouse while in the bios. Read page 2-12, section 2.2.1). This will explain how to move about while in the bios. Once the Bios opends you will be at the main menu. If your SATA drive is correctly connected you will see its model number listed there.
If you have two SATA drives connected you should see both. Take note of which is the master SATA1 drive. All SATA drives run as master drives. While in the Bios, SATA drives are shown from top to bottom. First /top drive will be the master drive. Next drive down is considered as slave.
Than open (OnChip SATA controller). Set this to [Native Mode] or to [SATA]. See page 2-16, section 2.3.5
Than open Boot. See page 2-30, section 2.6, Open Boot Device Priority section 2.6.1 Here is where you need to set the boot order.
(The boot order is not set correctly & this is why windows does not see your hard disk drive & showed the message "No hard drive listed").
If you have a floppy disk drive connected to the system set it as,
[1st Boot device]
Change 2nd Boot Device to [CD-ROM]
If you have two CD/DVD-ROM drives in your system make sure you set the Master CD/DVD-ROM here & not the slave CD/DVD-ROM drive.
3rd Boot Device should be the primary [SATA1 drive], connected to SATA1 port on the motherboard. See page 2-30 section 2.6.2
The drive with windows installed shoud be listed as 1st.
Save your changes & exit the bios. Your system will auto re-start.
If you had a working operating system on the drive it should load.
If you need the motherboard manual or drivers you can download them from Asus web site link below;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
Cheers!
If you are still having troubles, post your question here.
Mike
Sep 24, 2009 | ASUS P5S800-VM Motherboard
My computer shows to setup array and does not detect one hard disk
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
May 16, 2009 | ASUS Computers & Internet
Second harddrive
Make sure its jumper is set as slave, if you have a 40wire ribbon cable, and cable select if you are using a 80 wire ribbon cable, if it is on the same ribbon cable.
If it is on the second ide cable, by itself keep it as master.
Jan 15, 2008 | ASUS M2N-MX Motherboard
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
Foxconn 865G7MF-SH Motherboard Logo
103 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
