Question about Sony KV-27S42 27" TV
Sony KV-27S42 27" TV Problem
Color distortion on side of screens. Degausser proble??
  • 1,139 Answers
Hello BrianMcL
You are 100% correct, you will need a degaussing coil to take care of this problem. The instructions on how to use it will be included with the degaussing coil.
I hope this helps,
Thank you,
Posted on Jul 23, 2008
Magnetized needs degaussing
proceed with this steps and fix it. God bless you
    • 1 Turn on your Sony Trinitron television.
    • 2 Flip the power switch on your degausser.
    • 3 Maneuver the degausser's coil so that it is a few inches away from the face of the screen. Draw the center of the degausser coil around the entire perimeter of the screen, and then return the degausser to the middle of the screen.
    • 4 Slowly back away from the Trintron's screen. This serves to decrease the degausser's impact on the CRT's magnetic field to zero. Continue backing away until you are about five feet away from the screen
    • 5 Flip the power switch on your degausser to turn it off. The CRT's magnetic field should return to its normal state and the picture quality of your Sony Trinitron should improve.
Oct 15, 2012 | Sony KP-53HS10 TV
I have a Bush RF6685VPL/A and the screen colour is very distorted. It looks like a blue red circle in the middle, with a blue and green ring around it.
Good day!
That problem is usually happen when the TV is near the magnet or the speaker.
You have to do is demagnetized the screen of your TV using screen Degausser.
The picture looks like this:
Just plug-in the degausser and push the button in front of your TV.
If you did not have that degausser please buy it to this link:
                                   Thank you and don't forget to rate my answer.
May 10, 2011 | Televison & Video
Does the sony KV-30HS420 TV used a lamp..if yes where to lacate it
the KV-30HS420 model is a CRT based set and thus has no "lamp". What is hte proble with the set?
Mar 06, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My sony 24in flatscreen has green color on right
dont power your tv near sound box or machines with magnet,
switch off tv, get a magnet and pass it all round your screen, it will clear with no time
Mar 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trintron KV-36HS500 TV color distortion
Sounds like the set is out of degausing, you will need someoen with a degausing coil to come and fix it. Should take all of 10 seconds and cost $100 or less. Let me know if you need more help.
Sep 11, 2008 | Televison & Video
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
KV-36XBR200 Green in lower left corner
The most common cause is, shadowmask inside of the CRT is magnetized. It sounds by your description that the TV's internal degausser for the CRT is not working. This is serviceable by a service tech.
Most of the time the cause of a failed degausser is the thermoresistor. This is a common type of failure.
Another cause that can show the fault you are seeing is if the shadowmask in the CRT is defective. Sometimes the mask is damaged when the set is being moved, and is accidently banged against something. The CRT is sensitive to this type of treatement.
If the mask inside of the CRT is defvective, the only fix is a new CRT.
Jerry G.
Apr 25, 2008 | Sony KV-36XBR450 36" TV
Rings of Color
You will need a degausser. Check out Wikipedia for the definition. Look on ebay or your local TV repair shop. Cost should be $20-$100.
Dec 13, 2007 | Panasonic CT-27SX12 27" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27S42 27" TV Logo
126 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
