Question about Refrigerators
My fridge it seems theevaporator fan in the freezer is not running but the compressor and thecondenser fan are the fridge part is warm THANKS
  • 481 Answers
It may just be a bad fan motor ($30). but i would check for any ice or frost buildup in the freezer that may be interfering with the fan.
Posted on Jul 06, 2008
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
Jan 27, 2014 | Refrigerators
Fridge does not seem cold enough. It is maybe 12 years old. Do I need a new fridge
The heat between the doors is normal but not really hot. if sides and between the doors is real hot then you have an air flow problem. Vacuum coils under it and coils by condenser fan. Check your Condenser fan by compressor.
Jul 28, 2013 | Refrigerators
Fan in Freezer portion not running, compressor works
The door switch, some fridges run the fan on door closed only.
Jul 10, 2013 | Frigidaire FRT17G4B Top Freezer...
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Sep 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
